6.0 head valve size
Old May 25, 2009 | 06:02 PM
chevy6.0fan's Avatar
Default 6.0 head valve size
I have a set of iron heads off a 99 6.0L that are fine except a couple of header bolts are broken off on one side. I also have a set of aluminum 6.0L heads from an 04 LQ9. A couple of valves on the aluminum heads are bent. Can I just swap the valves from the iron heads to the aluminum ones or are they different somehow?
Old May 25, 2009 | 06:09 PM
Mangled03gmc's Avatar
Baltimore Whore
317 heads
Combustion chamber Volume:71.06cc
Intake Volume:210cc
Exhaust Volume:75cc
Intake valve Diameter:2.00-inches
Exhaust valve Diameter:1.55-inches
Iron heads should be teh same,other then being steel
The_W
Oct 28, 2015 09:00 PM
FlowmasterMufflers
Jul 30, 2015 05:03 PM
jmarkway
Jul 18, 2015 09:23 PM
4B11T
Jul 13, 2015 03:48 PM
jrplz
Jul 9, 2015 12:07 AM
