6.0 Head ?'s
Old Jun 17, 2004 | 08:07 PM
Last Call's Avatar
TOTM: January 2007
Default 6.0 Head ?'s
I was thinking about changing out my 5.3 heads to 6.0 heads so I can run more boost. How much boost do you guys think I could run with those heads? 10,11, 12?? How much additional hp do you think? Just trying to see if its worth the 400 or 500 bucks. I know if would to have it retuned. Thanks
Jason
Old Jun 17, 2004 | 09:00 PM
greentahoe's Avatar
Does the Radix spin high enough to make that much boost???
Old Jun 18, 2004 | 09:09 AM
01Blackerado's Avatar
you could put unlimited amounts of boost on those heads technically. Really without blowing your engine you could put at least 22 psi
Old Jun 18, 2004 | 12:10 PM
The Radix won't generate enough additional boost to make it worth your while.You can run about 91/2 lbs of boost with the 5.3 heads with little or no knock.The supercharger doesn't generate higher boost because your 5.3 heads flow well enough that thay are not a restriction.The loss in compression will cost you power that you'll be hard pressed to makeup,because you won't generate additional boost with the freer flowing 6.0 heads.
Old Jun 18, 2004 | 02:08 PM
Old Jun 19, 2004 | 11:39 AM
ktmrider's Avatar
Look in the "Internal Engine" section of this site at the top. There is an excellent thread about the head volumes, CR, flows, etc. that may help you answer some of your questions.
Whitt1 is right, the Whipple would be hard pressed to make more than 10lbs of boost. The big drop in your CR with the 6.0L heads would not make up for any amount of extra boost. Most guys that drop the CR are running biiiiiig boost pressures like 20lbs+ to keep from having major detonation. Plus, the overall flow rate would be affected due to "valve shielding" caused by the smaller bore size of your 5.3L compared to the 6.0L 4" bore.
Old Jun 19, 2004 | 03:48 PM
greentahoe's Avatar
Does this mean that running 6.0 heads on a blower capable of higher boost levels would be a good idea?? What else would be needed to make this reliable??
Old Jun 19, 2004 | 04:23 PM
NovaTime's Avatar
i'd like to see the octane rating of that gasoline!
Old Jun 21, 2004 | 07:35 AM
93 octane but some incredible injectors like 57#- 6x will do fine
greedygenius
Sep 3, 2015 06:51 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
JordanH
Aug 8, 2015 07:59 PM
steves86ta
Jul 28, 2015 10:21 AM
