6.0 cam performance!!!!!!!!!!!!!
Old Jan 31, 2009 | 02:10 PM
SynergyV8's Avatar
You're going to spend $4-500 on a new cam setup for 10-15hp, why not spend the extra $100 for a nitrous system and spray 100-200 or more?
Old Jan 31, 2009 | 03:02 PM
budhayes3's Avatar
PT's Slowest Truck
I agree that it's time for some headwork, 2* more of duration won't net enough gains IMO. How about a set of WCCH StageII 317's and the afore mentioned 228 cam?
Old Jan 31, 2009 | 03:27 PM
get you a tbss intake and find a used 90m tb on the net and then look for the cam. IMHO. I ran back to back 8.2x's with a stock cam ,stock heads and a 4l80e w/ 3600 P.I multi disc and 3.42's.
Old Jan 31, 2009 | 04:10 PM
12sec.5.3's Avatar
Can't run tbss intake without upgrading to ls3 heads. The intake ports don't match.
Old Jan 31, 2009 | 05:25 PM
well it fit perfect on my 317's I think you are talking about the l76 intake the tbss has the l76 runners and top with cathedral ports there are a couple people on this board with the same setup.
Old Jan 31, 2009 | 06:20 PM
Truckshop's Avatar
tbss came with 243 heads which are cathedral port. the intake also fits my 317 heads.
Old Jan 31, 2009 | 07:16 PM
getonit's Avatar
what kind of difference would I see with the tbss intake and tb. How much could I expect out of the 3800 stall with 4.10's and slicks shifting at 6700 rpms. when it ran 8.0s
at 85mph with a 1.84 60ft it was on the 3000 stall and 3.42's with m/t dr's shifting at 6000rpms. I might try turning this cam to 6700rpms and try the tbss intake. Do you think I could break mid to high 7's? I dont care much for 1/4 mile times cause there are no close tracks only 1/8
Old Jan 31, 2009 | 07:33 PM
stock48's Avatar
9 Second Truck Club
That should get you into the high 7's for sure. Mid 7's would be ~11.8 sec 1/4 mile which might be a lot to ask with no head work. looks like you are mid 12's right now. Takes a lot more to pick up couple tenths in the 1/8 mile than 1/4.
Old Jan 31, 2009 | 07:41 PM
getonit's Avatar
I have only ran the 1/4 three times and I ran 12.6 all three times I dont remember the mph but the 60's were all 1.8x. I fugured the 3800 stall and 4.10s with slicks and I can try to turn the 224 a little higher rpm I might can get some high 1.6x 60's. I have a spare set of 317's milled 30 thousanths how much would the help
Old Jan 31, 2009 | 07:54 PM
getonit's Avatar
I could be wrong, but with the stock tb, truck intake, and no headwork, I think you're asking a lot out of a cam. I'm no guru, but I'd leave that cam and get a good set of heads. Maybe even a fast intake with a 90mm or so tb. A cam can only do so much. All the engine parts must work together to make a strong engine.
Check this out
https://www.performancetrucks.net/fo...d.php?t=432868
