6.0 Buildup - Your advice wanted.
#321
Am I mistaken that O2 sensors do not affect the engine until warmed up and in closed loop? If so, then they have nothing to do with the bucking and back firing, correct?
#322
All your issues are within your tune. You really need to buy a Wideband 02 sensor as stated above, it will tell you what is comming outta that motor, and will allow you to monitor it accordingly
#324
#329
#330
I just put a fuel pressure guage on it. It was reading 50 PSI at idle. This is on a cheapy Autozone guage. I swapped in the pressure regulator from my 5.3, and it's now 54 PSI at idle, and about 52 with a few RPMs. Is it normal for it to fall for a split second when you blip the throttle? Also, the needle "quivers". I'm assuming this is normal?
Probably time to change the fuel filter if nothing else. It's been a while.
