6.0 Buildup - Your advice wanted.
Old Sep 17, 2010 | 09:05 AM
  #241
blsnelling's Avatar
Blow by being rings? Bummer. Guess I'll have to address that before I can sell it
Old Sep 17, 2010 | 09:54 AM
  #242
blsnelling's Avatar
OK guys. Help me out with some answers here. I'm going to number the topics, and you can reply to that number.
1. Did a 2004 6.0 have a PCV? If so, how was it plumbed? Perhaps I'll just install my 5.3 valve covers on this engine.
2. How do I retain the MAP sensor? It doesn't snap in like it did on my 5.3, yet it shows the same MAP for both year trucks.
3. Where do I connect the line coming off the front of the passenger's side valve cover? Can I just cap it off? Seems like running it to the intake would defeat the purpose of a catch can.
4. What do I need to do for my air intake plumbing? The one from my 5.3 is way too small for this 90mm throttle body. Can I use a NBSS intake setup?
5. Where do I connect the chains to lift these engines?
Old Sep 17, 2010 | 10:19 AM
  #243
brent5631's Avatar
1. The later models had just a nipple with an orifice no actual valve. you hook it up the same as any other pcv system.
3. the passenger side goes to the intake tube before the TB.
5. I connected mine from the back of one head to the front of another and ran the chain across the top of the intake.
Old Sep 17, 2010 | 10:35 AM
  #244
blsnelling's Avatar
Thanks for the info.
1. I'll just swap back to the original valve cover then. I want to keep it as original as possible, for serviceability ease.
3. Doesn't that defeat the purpost of a catch can?
5. So lifting by the heads is the acceptable method? No risk with head gaskets?
Old Sep 17, 2010 | 10:43 AM
  #245
brent5631's Avatar
3. no because when the tb is closed there is a pressure difference that draws air into the passenger side.
5. That is how mine went in.
Old Sep 17, 2010 | 11:00 AM
  #246
bgray's Avatar
TOTM: June 2007
Lifting by the bolts on the back of the head are fine, Ive pulled probably 10 motors like that, its there for lifting.
Old Sep 17, 2010 | 11:24 AM
  #247
blsnelling's Avatar
I guess the biggie I need help on then is #4. What year did they go to 90mm t-bodies? I'm hoping there's a Airaid MIT I can use to hook up my factory airbox.
Old Sep 17, 2010 | 11:41 AM
  #248
brent5631's Avatar
They went to 90mm on the 07+ trucks. So you might not find something that will work exactly.
You could use some aluminum and couplers as some have done.
Old Sep 17, 2010 | 01:00 PM
  #249
blsnelling's Avatar
My MAF is 3 1/2" ID. Does it need to be bigger? What do they measure on a '07+? None of the local parts stores have one in stock to measure. Did you just reuse the original on yours?
Old Sep 17, 2010 | 01:23 PM
  #250
brent5631's Avatar
Reused mine. then 4in aluminum to 4-4.5in reducer to tb.
