6.0 Buildup - Your advice wanted.
Old Sep 8, 2010 | 08:56 PM
  #151
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
That is the high pressure variant, the 10296 is the high volume. Also depends on how you set up your bearing clearances. Mine is a stock LQ4 with unknown miles(looked clean and low mileage), wish I had more history on my motor. Ive never went to an aftermarket pump as Ive always been able to get what I needed out of a stock pump whether by oil weight, shimming, porting or just running it stock.
On a few cam swaps Ive done, I pull the pump off, shim the spring, and port the entrance where the pick up tube goes in and thats usually enough to get me close to 10#s more oil pressure.
Old Sep 9, 2010 | 08:22 AM
  #152
blsnelling's Avatar
My engine will have factory bearing clearances. The crank was only polished and all bearings are standard.
Old Sep 9, 2010 | 01:23 PM
  #153
blsnelling's Avatar
Just talked to the shop on the rods. He checked them for size with the ARP bolts. Five of them are good. Two of them are tight, which can be honed for standard bearings. The last one is about .002" oversized. I told him to check the last one with factory bolts. If it fixes it, I told him to oput all factory bolts in them. If not, then hone the two tight rods with the ARP bolts and I'll come up with another LS2 rod. Bummer. Better safe than sorry though. Glad I had him check them.
Another though, would it be a bad idea to size the one oversized rod, and leave the others all standard? I don't see any point in resizing them all to oversized if not needed.
Old Sep 9, 2010 | 01:35 PM
  #154
blsnelling's Avatar
I think I know what the outcome of this is going to be. I don't believe the factory bolts are going to fix this. With 5 of them good, 2 tight, and 1 out of round by .002", I think it's simply the rods themselves. With that in mind, does anyone have a OEM LS2, LQ9, or 04+ LQ4 rod they would sell me?
Old Sep 9, 2010 | 01:46 PM
  #155
RibeiroBJJ's Avatar
Praise The Lowered
http://cgi.ebay.com/ebaymotors/GM-GE...Q5fAccessories
Old Sep 9, 2010 | 01:49 PM
  #156
blsnelling's Avatar
Thanks.
Old Sep 9, 2010 | 01:55 PM
  #157
blsnelling's Avatar
I just called the shop and told them to leave the ARP bolts in, resize the two tight ones, and I'll come up with another rod. I can order the one on eBay used and wait, or I can have a new one tomorrow for $119
Old Sep 9, 2010 | 02:20 PM
  #158
blsnelling's Avatar
I bit the bullet and ordered a new one. Will have it tomorrow. I don't want to take a chance of getting a used one, only to find that it has ussues as well.
Old Sep 9, 2010 | 05:40 PM
  #159
blsnelling's Avatar
The Comp trunions are installed. Piece of cake with my new Harbor Freight 1 ton arbor press. Took maybe 1-1 1/2 hours total.
Old Sep 9, 2010 | 05:56 PM
  #160
1slow01Z71's Avatar
Is the 1 ton HF press big enough to put a carrier for pressing on bearings? Ive been meaning to pick up a press and this would just be another use for it
