6.0 build
Old Jul 7, 2008 | 08:22 PM
lo&sloSierra's Avatar
Default 6.0 build
hey i got me a lq9 short block today and im slowly going to build this motor up, any suggestions on what to build it up with? head/ cam combo? etc.? o and i plan on eventually generating a good amount of power out of this, and i dunno if a built 4l60e will hold up, any suggestions?
Old Jul 7, 2008 | 08:28 PM
Stoichiometric's Avatar
Any n2o or forced induction planned? I would do some research on the L92 heads if you are thinking about staying N/A. They flow very good numbers and their is a ton of good info on them on ls1tech. Get the best heads you can afford and then choose the cam to reach your ultimate power goal.
Old Jul 7, 2008 | 08:30 PM
GMCtrk's Avatar
I've done some research, and for the cost (if you're on a budget) the L92 heads don't seem worth it. Plus you have to get the L76 intake too. The 317s flow pretty good too.
Personally I plan on going with a Vinci 210/218 cam for my LQ9, but I want low end torque. I rarely go over 3000rpm.
Old Jul 7, 2008 | 08:41 PM
skeet's Avatar
yes sir found some damn good info on this, this is the route i am fixing to go myself after a dyno and a few track times with the setup i have now..
if this is for a truck go with the l92 truck intake, you wont have to change anything. except if youre cable driven then a a modded bracket maybe needed, dunno foresure but i will eventually try this
gonna slap a 232 236 58x 59x lsa10 cam in it ( i think lol ) these are just thoughts. i missed a pretty set of heads today ( dayum)
Old Jul 7, 2008 | 09:28 PM
GMCtrk's Avatar
My point was that you can't use the stock 6.0 intake. It's just more cost.
232/236....I'm guessing you don't DD this.
Old Jul 8, 2008 | 07:24 AM
well i have a 4.8 in the truck now im about to throw a 100 wet shot on, that i plan on putting on the 6.0 when its done, and its dbw, so whats a good set of heads and cam? im not wanting to break the bank but i want to turn some power, and with that being said will a built 4l60e still hold up?
Azim05
Aug 27, 2015 05:33 PM
spiritfish
Aug 23, 2015 09:58 PM
Abuckeye
Aug 19, 2015 06:11 PM
USMCvet0311
Aug 14, 2015 10:28 PM
05GMC4.8
Aug 7, 2015 09:55 PM
