6.0
#31
Originally Posted by ramsey rider
i took your advice from everyone here and bought a 6.0 w/400 miles on it today for 1500.00 top to bottom w/all acc.
will i have any problems bolting it up to my 1500 sierra and will there be any wiring harness issues or computer problems
Wiring harness - it's the same one, you will not have any problems. Be sure you plug everything back up. EVERYTHING goes back the way that it was.
like do i need the comp out of the vehicle the motor came out of.
Yes if you want an extra computer (PCM), but there's no need for it.
i know theres tons of post about swaps but this is a van.
oh will my 4l65e bolt up ok what do ineed to do to make it work long stort short.
Transmission work better? a shift kit will make a world of a difference. Do a search for "Transgo HD2" It's a true reprogrammer for your trans, and it helps with the life of it.
Summary - all that you're changing is the block and heads, nothing else, everything else is reused again.
#32
Originally Posted by RandomHero
that ****** weighs 9000lbs? Holy crap
Like our trucks GVWR is 7000(for instance my truck weighs 5200 unloaded just for figuring purposes) so it can carry 1800#s in addition to the vehicles weight.
#36
Originally Posted by nightrunner
the only difference-performance wise between the lq4 and lq9 is a small compression diffrerence ( higher on lq9) and the tune
yes in stock form the lq4 what you have has lower hp than the lq9
#38
nope both are iron block
99's and some 2000 had iron heads
Iron heads have the longer crank, and that's bad unless your going to run an 80e trans
There's lots of pics about this floating around, use the search at the top.
#39
im starting mine tomm. will the flywheel off the 6.0 or visa versa work on the 4l65e of mine in my truck ?im doing it over the weekend and i dont want any speed bumps .so everything off the 06 6.0 will fit on my o4 sierra ?if you have any tips for me id appr. them .ive got my 4.8 hyper programmed do i just leave it that way till i get tuned .is it driveable without tune ?its my dd and i dont know how quickly i will get the tune .
Get rid of the hypertech, it's crap, and it's useless, ebay it for 10-150, and never pick it up again
1. get a stock 6.0 tune
2. get an engine hoist
and read up some more https://www.performancetrucks.net/fo...earchid=546881
