6.0
Alot of the LQ9's extra HP comes from the PCM tuning, along with the higher compression. An LQ4 6.0 is plenty powerful, especially with some supporting mods. First thing that I'd do before bolting that bad boy in is to find a cam that suits your needs, get some strong valve springs and push rods, bolt er in, get it tuned and let it rip!
Originally Posted by gmforlife
I would also like to know the difference in hp rating. I know that the lq4 is lower compression like previously stated, but what is the difference hp wise. ANd when shopping for a 6.0, how do you tell by the vin if it's an lq4 or lq9? i know the 8th letter is different, but which is which?
lq9's were rated at 345 in all applications.
Originally Posted by ramsey rider
should i think about upgrades to get a tire burner or should it be strong enough stock?i do have 3.73 and id like to keep up with my wifes escalade lol
normally sellers are commanding higher prices for the lq9 than the lq4 and for many its not worth the extra money for that little bit of compression bump, you could probably mill the heads to get the difference in comp. for less than the diff in cost
can you tell by the vin if so how i do have the vi n# the place i got it from said i could go on the gm site and find out is that true and if so does anyone have the link to site .or i can give youguys the vin
