5v source
Old Nov 3, 2008 | 09:53 PM
PSM's Avatar
PSM
Default 5v source
where can i tap into under the hood to feed two sending units a steady 5 volts?
Old Nov 4, 2008 | 11:28 AM
budhayes3's Avatar
PT's Slowest Truck
Hmmm, good one....don't most of the sensors use a 5v reference? Maybe tap into the TPS, just not sure which wire....
Old Nov 4, 2008 | 12:34 PM
Truckshop's Avatar
Tp Sensor, Map Sensor, Cam Sensor, Ac Pressure Transducer. Take Your Pick. What Are You Trying To Hook Up?
Old Nov 4, 2008 | 12:39 PM
PSM's Avatar
PSM
I have a gm map sensor and gm oil/fuel pressure sensor that I have installed for the boost and fuel pressure, but I'm not sure which wire I can get 5v off to power them. I suppose I can just take a multimeter and start testsing away but I figured I would check here before I did that
Old Nov 4, 2008 | 12:46 PM
Truckshop's Avatar
When I Installed My Fuel Pressure Sensor I Spliced 5v And Ground From My Map Sensor On The Top Of The Intake Cause It Was The Closest. Give Me Your Vehicle Info And I Can Get You Wirecolors.
Old Nov 4, 2008 | 05:13 PM
Wilde Racing's Avatar
How do I change this text
egr. safe, and usally unused...
Old Nov 4, 2008 | 06:37 PM
PSM's Avatar
PSM
The vehicle is in my sig. Its an 2003 sierra denali with the lq4. Not sure what else you need. Lemme know, thanks!
I don't think I have egr.. there is nothing comming the exhaust manifolds? Do you mean there could still be wiring there? Got any idea what wire colors or where to look?
Old Nov 4, 2008 | 07:49 PM
built408's Avatar
Why do your sending units need 5v?????
Old Nov 4, 2008 | 07:50 PM
PSM's Avatar
PSM
yip, both of them. They are gm parts, not aftermarket ones and i believe gm uses 5 volts of lots of its sensors
Old Nov 4, 2008 | 08:54 PM
budhayes3's Avatar
PT's Slowest Truck
I believe that 03's don't have EGR, I thought that they did away with it in 02...at least on the 1500's...
