5v source
Old Nov 9, 2008 | 09:55 AM
  #21
PSM's Avatar
PSM
Originally Posted by Wilde Racing
Yep, But I'm pretty sure you can still use the pin from the pcm ...
Got any idea what pin that is?
Old Nov 9, 2008 | 12:07 PM
  #22
Truckshop's Avatar
Originally Posted by PSM
wouldn't I want to use the same ground wire the sensors use since that is what the ecu is using as reference to give 5v off of?
the ecm just outputs the 5v signal. it only monitors the the signal wire. and it all ground through the chassis to the battery. you just need to steal 5v.
Old Nov 9, 2008 | 12:28 PM
  #23
dewmanshu's Avatar
Moderately Differentiated
Originally Posted by Truckshop
it should be fine. if you are worried here is a link to a 5v power supply.
http://www.aeroforcetech.com/sensor.html
I was gonna suggest this. Tapping 12volts is fine, but I never liked the idea of taking or sharing five volts with sensors. I know plenty of people are doing it, I'd just make a new source for it was me. Cheap insurance.
Old Nov 9, 2008 | 02:35 PM
  #24
Truckshop's Avatar
gm is pretty good about using separate 5v circuits for there sensors. ford on the other hand just splices to 5 or 6 different sensors off of a single circuit.
Old Nov 9, 2008 | 11:15 PM
  #25
PSM's Avatar
PSM
ok where do you guys suggest i get a good switched 12v source from
mhorn0817
Jul 8, 2017 01:54 AM
DrX
Aug 11, 2015 07:25 AM
6.Slow06
Jul 7, 2015 09:19 PM
