.583Lift @valve, 02-04 ls6 yellow spring??
Old Mar 22, 2006 | 07:42 PM
RGMEPP's Avatar
Default .583Lift @valve, 02-04 ls6 yellow spring??
yellow made in Ger. spring for ls6 @ .583 valve lift is pushing it a bit. Will it fly???
Old Mar 22, 2006 | 07:54 PM
99Silver6.0's Avatar
Too much lift for LS6 springs. Good idea to run a Comp 918 for that cam.
Old Mar 23, 2006 | 02:36 AM
ktmrider's Avatar
Very close to coil bind there, I also would look aftermarket ( 02+ Z06 cam lift is 0.550" on yellow springs ).
Old Mar 23, 2006 | 07:32 AM
98TAauto's Avatar
some ls6 springs were supposed to hold .570 i think? But .583 would need 918's for sure
Old Mar 23, 2006 | 08:41 AM
SS_bnoon_SS's Avatar
There are a few people running close to .600 lift on Z06 springs in the LS2 GTO world. I will be running above .580 lift on mine and don't plan to have issues.
Old Mar 23, 2006 | 07:12 PM
Thats all well and good. But I would be concerned about float. Id want a better spring running a cam with that much lift.
Old Mar 23, 2006 | 08:10 PM
FarmerBeau's Avatar
Sexy Party Mod
You can run stock springs and it will run but it WILL float! The LS6 springs arent gonna cut it.
Old Mar 24, 2006 | 09:36 AM
They've been reported to not float on those applications...
Old Jun 3, 2006 | 11:49 AM
RGMEPP's Avatar
Ended up with comp. cams 54-450-11 specs as follows
54-450-11 ''XFI'' 260 Hydraulic Roller Cams
GM C/K Trucks 99-06 4.8/5.3L
Lift: .513''/.520''
Duration @ .050'':206°/212°
RPM Range: 800-5800
Lobe Separation: 115°
with 1.8 cranes lift at valve is .564/.572 runs stromg as hell, no float, no bind,p/v clearance greater than 3/16". all is well in strokerland.
Old Jun 3, 2006 | 02:06 PM
Okie5.3's Avatar
didn't blownchevy run ls6 springs with the gt2-3 cam with no problems? the lift on it is what .56x/.57x?
ARC
57
Feb 21, 2022 10:54 AM
BigEd_72455
Aug 8, 2015 04:49 PM
08lambochevy
Aug 7, 2015 11:42 PM
LARRY01Z28
Aug 1, 2015 10:15 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
