5.3L random ticking?
I have a 5.3L with 77k miles on the clock that has a random clicking or tapping sound. It developed about 2 weeks ago while driving down the interstate under light load and it comes and goes randomly. It sounds like a bad lifter but it won't do it all of the time. I checked my rockers and pushrods and they look good and none of them were bent. Do you guys think that I need new lifters or try some other things first? How worried should I be.
A Friends Truck Of Mine Made That Kind Of Noise...but It Was Coming From The Alternator....the Noise Will Come And Go Once In A While...we Changed The Alternator Today And It Stopped....might Wanna Check It Out
BTW-MY FRIENDS TRUCK IS A 06 CHEVY
The tapping noise is deffinitely coming from the engine and it sounds like lifter tapping. The only time it does it loudly is on startup and after I do a hard pull but it goes away after some normal driving. How worried should I be? Should I go ahead and install some new lifters or just keep driving it?
if its only when u first start it or when its cold it might just be piston slap...heres a couple threads started a couple days ago
https://www.performancetrucks.net/fo...d.php?t=424100
https://www.performancetrucks.net/fo...d.php?t=424094
or as if you said when its under a load like going up a hill it might be pinging or slight knocking...before I got my newer PCM and tune my truck used to do it a lot...
+1...why are you 99% sure...I dont see why in the past 2 weeks it just appeared...maybe you got a bad batch of gas or something...just a thought
I am using 93 octane and spraying a ton of meth on high boost.
I can here the noise through the valve cover with a stethascope and it sounds like a lifter so I'm pretty sure that's what it is. The thing that I'm wondering is if it is only doing occaisionally should I be that worried?
