5.3L piston ring question?
Old May 28, 2015 | 02:12 PM
JL Sargent's Avatar
Default 5.3L piston ring question?
This is a 5.3L DNJ piston oil control ring expander. There is a small wire threaded across the ends of the ring. this wire is about 3 inches long. What purpose does it serve? Should that be removed before installing. Never seen one like this. I have a call into DNJ about it. They will call me back.
Old May 28, 2015 | 08:34 PM
1FastBrick's Avatar
Custm2500's Rude Friend
It holds the ring together so it doesn't bunch up or go over it self.
It's perfectly normal
Old May 28, 2015 | 08:49 PM
JL Sargent's Avatar
Seems like the wire would travel away from the end connection when the engine is running? Anyway, thanks for the reply. I've never seen one like that before. I've installed maybe a dozen pistons, therefore making my experience level somewhat limited.
Old May 28, 2015 | 09:19 PM
1FastBrick's Avatar
Once installed correctly, they stay locked in place. the wire portion should stay in the outer portion of the ring, not protrude inward like shown on the left side of the current picture above.
There should have been instructions with the ring pack. Sometimes there printed on the inside of the box.
Old May 29, 2015 | 07:39 AM
JL Sargent's Avatar
Thanks! I hope to get these pistons installed today.
ferrellrooster
Mar 6, 2025 03:22 PM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
JordanH
Aug 8, 2015 07:59 PM
USMCvet0311
Aug 1, 2015 07:45 AM
1320Chicken
Jul 14, 2015 10:58 PM
