5.3L pinging problem
Old Jun 5, 2015 | 04:20 PM
stock48's Avatar
9 Second Truck Club
What software do you tune with? 30 deg is a lot for a stock motor on 87.
On that note, I've seen a couple motors not show KR and ping. They would show KR and then zero out before they would ping.
Run some top end cleaner through it. A stock tune should not command that much timing at WO even with 6 deg being added.
I have a really old HP tuners that I have always used on my truck so never really updated it or anything. Im running 91 oct cheveon fuel best we have out here.
Originally Posted by madmann26
A stock program will not command 30 degrees of timing, anywhere.
I just checked a stock tune on HPT and the High Octane table commands at most 24-25 degrees @ .56g/cyl. The Low Octane table commands 20 degrees.
Sounds like a crappy tune to me.
Yea that's exactaly what it has in the high oct and low oct tables but it's adding somewhere else.
Originally Posted by BlackGMC
Look at the fuel spark correction table. It adds timing when the commanded AFR changes. That is where your most likely adding timing on top of the High octane table
Good point and that's kinda what I was thinking. I need to compair it to a known stock tune to see if that is what it's doing. Onlything I saw that is fishy about tune is it has 3.42 gears and has 29.7" tire selected in the speedo part. Shouldn't a tahoe have a 31" tire stock? Also speedo is a tad slow and that prob explains why. Tires on it are 285/55/20's.
Old Jun 5, 2015 | 05:13 PM
03sierraslt's Avatar
Those tires are like 31.5 or so I forget. I should know as I have them.
Old Jun 5, 2015 | 07:11 PM
stock48's Avatar
9 Second Truck Club
Could the cai be jacking with mafs and making it do weird ****? It has a Spectire or whatever it's called kinda cheepish looking cai on it. Gunna clean mafs tonight and replace knock sensors and we'll see what happens. Don't want to do too much because I have a lq4 with 243's and my 210/216, .532/112 lsa cam waiting to go in. Just worries me with the pinging. Maybe I should keep 317 heads on the lq4??
Old Jun 5, 2015 | 07:29 PM
GMCtrk's Avatar
Are you sure it's not a mechanical issue? Have you pulled the valve covers to see if there is some problem on the top end causing a tapping? Pinging right off idle seems odd.
Old Jun 5, 2015 | 08:59 PM
I tuned a 2500hd last week that showed massive KR right off idle, turns out motor mounts were loose.
Old Jun 5, 2015 | 10:02 PM
George C....'s Avatar
Formerly ScreamingL
is this a joke?
Old Jun 5, 2015 | 10:43 PM
Reflash it to full stock, put a stock air box on it if you have one and check the plugs. Run top end cleaner through it and once all this is done you will have a baseline you can start from and go from there.
Check the MAF make sure it's clean and has the screen installed. If it's missing the screen find another MAF.
Old Jun 5, 2015 | 10:52 PM
stock48's Avatar
9 Second Truck Club
Wow! lol
Originally Posted by George C....
is this a joke?
Nope needed a kid hauler my reg cab and nova were not too practical.
Yea I need to check all that. Dnt really want to deal with dealer tho they are rapists around here. I need a stock 5.3 HP tuners tune to compare every table etc to.
Old Jun 6, 2015 | 01:12 AM
1FastBrick's Avatar
Custm2500's Rude Friend
Excessive Carbon build up from Shitty gas usually causes the pinging in these engines. Run some fuel injection cleaner through it.
PM Me the Vin number. Let me see if I can get you the factory GM calibration for it.
By any chance is this an L59, Flex fuel Tahoe???
Old Jun 6, 2015 | 07:07 PM
stock48's Avatar
9 Second Truck Club
Ok thanks! I will get you the vin tonight.
