5.3l head suggestions, need a decision asap
Old Mar 4, 2009 | 10:20 PM
gmtech03's Avatar
Registered User
Default 5.3l head suggestions, need a decision asap
Ok guys i need some help here. I've got an 03 sierra with the lm7 5.3 motor. I have just recently found that my heads are leaking coolant.(common problem with 5.3l stock heads). I am wanting to upgrade the heads. I was told a good setup would be either the ls1 heads and cam or the ls6 heads and cam. But i also was told that the ls6 setup has a problem with shrouding the valves. any info or suggestions would be great. I need to know asap so that the problem can be fixed before other damage is caused. thanks
Old Mar 4, 2009 | 10:26 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
welcome to performance trucks, I have never heard that the head leaking is common, not at all. Swapping to the LS6 heads will lower compression, losing you power unless you mill them.
Old Mar 4, 2009 | 10:28 PM
00ChevyScott's Avatar
Wearin' da big hat
I've never heard of that either. Someone is bullshitting you.
Old Mar 4, 2009 | 10:31 PM
gmtech03's Avatar
Registered User
Default common problem
yeah the coolant leak is a common problem on the 03's to i think the 04-05's maybe. is has something to do with the way one of the bolt holes is machined. Its actually a week spot and will crack. I work at a dealership and have seen is several times. so what are the best heads to go with?
Old Mar 4, 2009 | 10:36 PM
ss454327's Avatar
Texas-speed.com actually sells a 5.3 head very often as a performance part on LS1 cars. I would go with a set of their heads and cam packages.
http://texas-speed.com/shop/item.asp
5.3lSilverado
25
Aug 29, 2016 12:48 AM
thunder550
Oct 8, 2015 04:53 PM
GrooveCityZ71
Aug 31, 2015 12:05 PM
JordanH
Aug 8, 2015 07:59 PM
LARRY01Z28
Aug 1, 2015 10:15 PM
