5.3L conrod dimensions needed.
Old Apr 4, 2006 | 08:57 AM
TG02Z71's Avatar
Default 5.3L conrod dimensions needed.
Anyone know the big and small end diameters and also the distance between centerlines?
I am going to make some rods for a demo on a machine in our showroom, they will not be working parts but I want them to be somewhat accurate to a real engine's dimensions.
If they come out good maybe make a set for my engine that work.....
If you have more information that this please post it up, like wall thicknesses, bushings on the small end, how much meat on the big end, and what size rod bolts are typical for an aluminum or steel rod.
Thanks all.
Old Apr 4, 2006 | 11:44 AM
TG02Z71's Avatar
Best guesstimate then??
nobody knows the trouble I've seen......................
Old Apr 4, 2006 | 04:09 PM
TG02Z71's Avatar
ttt guys, someone must know this.
Old Apr 4, 2006 | 04:45 PM
TG02Z71's Avatar
Did this just for kicks.
Old Apr 4, 2006 | 08:22 PM
Flyer's Avatar
I can send you one, or 8 of them. Pistons attatched.
Old Apr 5, 2006 | 01:55 AM
ktmrider's Avatar
They are identical to the 5.7 and 6.0 motors, somebody should have info on one of those ( not me tho )....
Cool CAD drawing BTW.
Old Apr 5, 2006 | 05:56 AM
TG02Z71's Avatar
All I really need is one. The steel stocker dimensions would give me all the dimensions I need but putting those same dimensions into an aluminum rod would be a diaster if you ran them in an engine!!
Maybe I'll make some in chromoly steel too....
Old Apr 5, 2006 | 10:08 AM
vanillagorilla's Avatar
I can't help you with the dim. but post some pics when that bad boy is done. I say you get all the proper dim. cut it out of aluminum, polish it for bling factor and use that as your display and paper weight. Then I'll send you some titanium and you can cut me 8 real ones. Mmmm.....
Old Apr 5, 2006 | 10:24 AM
TG02Z71's Avatar
I have a large chunk of Titanium that I aquired through a hostile takeover for just such a project.
I will post up if I ever get some better info to design from.
Just found this.
http://www.campbellenterprises.com/m...minum_rods.htm
Old Apr 5, 2006 | 10:47 AM
ktmrider's Avatar
Found this:
Crankshaft Specifications
Material
Cast Nodular Iron Features
Undercut and rolled fillets.
Crank Pin Diameter
2.10” Main Bearing Diameter
2.56”
No wrist pin diameter but try this site http://www.smokemup.com/tech/ls1.php for some really cool stuff.
I seem to remember the wrist pin is 0.927" and the center to center length is 6.098". I have some time, I will check for more....
