5.3L bored to 4.000?
Old Jan 20, 2009 | 11:15 AM
Mike96z's Avatar
Default 5.3L bored to 4.000?
Is this possible?
Old Jan 20, 2009 | 11:25 AM
kbracing96's Avatar
no, max bore on a 5.3 is about 3.905
Old Jan 20, 2009 | 11:35 AM
Mike96z's Avatar
That sucks, well cool, thanks for the info. Do you happen to know the thickness of the cylinder walls?
Old Jan 20, 2009 | 11:42 AM
kbracing96's Avatar
They will vary, but even boring it to LS1 5.7 over bore size (3.905) they should be checked to be sure they're still thick enough.
Old Jan 20, 2009 | 11:51 AM
Mike96z's Avatar
Well for instance going to 3.900 bore for LS1 pistons, whats a good amount of wall to have left?
Old Jan 20, 2009 | 03:02 PM
jeforton's Avatar
i was under the impression that 5.3 and 6.0 blocks were the same except for the bore?
Old Jan 20, 2009 | 03:10 PM
Mike96z's Avatar
I wouldnt of thought that to be true because they wouldnt waste time boring the same block to make a 6.0 when they can just cast them for the bigger bore.
Old Jan 20, 2009 | 03:17 PM
jeforton's Avatar
makes more sense than my idea.
Old Jan 20, 2009 | 03:19 PM
regency's Avatar
have it sonic checked and that will tell you how far you can go
Old Jan 20, 2009 | 03:43 PM
00Silv4.8's Avatar
just buy a 6.0 block locally.
