5.3L to a 6.0L
Old Aug 10, 2007 | 03:00 PM
Default 5.3L to a 6.0L
Got a question for you all
04 Avalanche 5.3L
I'm planning to change the 5.3L to a 6.0L from a 03 Escalade.
I'm guessing it should be straight foward.
But is their a difference in the fuel rail setup from the 03 to 04 ?
I think I can run the 5.3L intake on the 6.0L right? same injectors?
I heard that some 6.0L would need something to bolt up on the 4L60 trans.
I figured it's cheaper to ask now than to do the job and find some suprises.
I know that the ECM will need to be tune for the 6.0L
Thanks in advance
Ron
Old Aug 10, 2007 | 03:58 PM
xlcooplx's Avatar
04 Avalanche 5.3L
Thanks in advance
Ron
not sure if your new engine has the returnless fuel rail or not. But yes, you can reuse your current intake/fuel rails on the new engine. Also, was that 6.0 previously bolted up to a 4L60E or to a 4L80E? If it was the 80E, you'll need to use the flexplate off of your current 5.3. If it was bolted to a 60E, you should be fine.
Old Aug 11, 2007 | 01:59 PM
It should be a straight foward job then.
Thanks for the info.
Old Aug 14, 2007 | 02:37 PM
agreif's Avatar
might help a little bit.
http://bertok.us/agreif/engine/EngineSwap.htm
calsdad
Jun 14, 2023 11:07 PM
SS94S10
Jan 3, 2019 01:57 PM
old motorhead
Sep 29, 2015 08:22 PM
Forcefed81
Sep 8, 2015 10:02 PM
