5.3 vs. 6.0
Old Sep 27, 2002 | 11:37 PM
redaddiction's Avatar
Default 5.3 vs. 6.0
Does anyone know whats the internal difference in this motors like if i swapped one in my truck i could use the same crank right? but what else is the same in this motors just wondering.
thanks
marc
Old Sep 28, 2002 | 05:30 AM
red53gmc's Avatar
Default Re: 5.3 vs. 6.0
The crank and rods are the only thing the same assuming you throw in a new cam. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Sep 28, 2002 | 02:51 PM
BigTex's Avatar
Almost BigKid - you corrected the correct answer. <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" />
The 5.3, 5.7, and 6.0 all have the 92 mm stroke. So they all have the same crank and rods. The 5.3 has a 96mm bore, the 5.7 has a 99mm bore, and the 6.0 has a 101mm bore.
The 4.8 has the same bore as the 5.3, but has a shorter stroke. It alone has a different crank and rod combo of these.
*the pre-01 6.0s had a slightly different crank and iron heads.
Old Sep 29, 2002 | 12:00 AM
BigKID's Avatar
I thought the 5.3 and 5.7 shared the same stroke and the 5.7 and 6.0 shared the same bore? So the 6.0 and 5.3 would have a different bore and stroke?
*edit*
I corrected myself. 5.3/6.0 share a 92mm stroke and the5.7/6.0 share a 101.6 bore and no shareing between the 5.3/5.7.
<small>[ September 28, 2002, 12:38 PM: Message edited by: BigKID ]</small>
Abuckeye
Aug 19, 2015 06:11 PM
JordanH
Aug 8, 2015 07:59 PM
05GMC4.8
Aug 7, 2015 09:55 PM
OLD BULL
Aug 1, 2015 05:00 PM
steves86ta
Jul 28, 2015 10:21 AM
