5.3 to6.0 swap
Old Jun 5, 2016 | 04:54 PM
Dstone's Avatar
Registered User
Default 5.3 to6.0 swap
I've got a 2000 gmc 5.3 with 260k. Been drinking oil so found a 6.0 but its the cast iron heads and longer crank. Question is ...can I swap cranks is all that the same internal?
Old Jun 5, 2016 | 05:03 PM
About20ninj45's Avatar
Yes you can swap cranks. Get rid off those cast iron heads and get a set of 317 heads, they will be better over the cast iron. Internals are slightly different, but I'd say they are close enough for what your trying to do... Someone correct me if I'm wrong
Old Jun 5, 2016 | 05:06 PM
madmann26's Avatar
Someone over on ls1tech supposedly used a 6.0/80e flywheel and drilled holes for the 60e.
Seems like a lot of hassle to swap cranks.
07NBSChevy
Apr 2, 2016 01:20 AM
chaosz71
Mar 29, 2016 05:21 AM
Shtbox
Mar 28, 2016 04:31 PM
tim wellington
Mar 22, 2016 11:38 AM
