5.3 out of 4wd into 2wd truck questions
Hey guy and girls so there's a 5.3 with wiring harness out of 4wd truck on craigslist and in planning using it in my 4.3 to 5.3 swap ut the truck it's going in is 2wd so will the harness work or do I need to find a 2wd 5.3 4l60e harness??thanks in advance for any info.Motor is a 2001 and trucks a 2000 gmc sierra so there both dbc.
A 4x4 transmission has a different length output shaft. It's shorter. You would have to disassemble the whole trans to change it out. Your better of getting a 2wd transmission.
The wiring harness would have additional plugs for the front differential and depending on which transfercase may also have additional plugs for the actuator and what not. It will still work in a 2wd application though. It would just have extra plugs that are not used.
