5.3 surging under load/reving
Old Mar 18, 2011 | 12:33 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
F-body tuning = truck tuning. It's the same process.
That said, just because they are new, does not mean they are good and working properly. Have you watched the fuel trims and the O2's switching on a scan tool? That's where I would start.
Old Mar 18, 2011 | 12:34 AM
TXjeepTJ's Avatar
Originally Posted by slow67
I had this problem in my car when I just copied over 5.3 tune into my LS1 tune. It make my O2s switch too fast and it surged rich, then lean (probably 2-3 times per second).
also, this sounds EXACTLY what it is doing- when you first start it up from being cold it runs find and then about 20 seconds later the o2's start showing output and that is when all hell breaks loose, on the scanner it is showing the ST FTRM1 and 2 going from -30% or so to +30% or so back and forth
Old Mar 18, 2011 | 12:39 AM
TXjeepTJ's Avatar
yeah I hooked the scanner up to it and it is showing crazy numbers (I described in previous post before this one)
I'll throw on some o2s I have laying around and see if that does anything, if not I should contact the tuner
TAPyvehc93
Dec 27, 2015 12:14 PM
pewter00
Sep 14, 2015 09:17 PM
sTNT971
Sep 11, 2015 02:38 AM
11MPG
Sep 10, 2015 08:34 PM
11MPG
Sep 8, 2015 04:52 AM
