5.3 with a "little" problem
Old Jun 10, 2014 | 06:28 PM
skaffy03's Avatar
Default 5.3 with a "little" problem
Hey all,
I was JUST under my Tahoe tightening down my collector flanges. I happened to look towards the front of the truck and noticed a rather large bolt laying on the top side of my plastic piece that connects to the main skid plate.
Turns out it's my crank pulley bolt!! I may have forgotten to torque it when I did my cam swap. The bolt looks brand new and never used like it flew off right after I did the swap and it's just been laying there.
Could a missing crank pulley bolt cause some issues such as random misfires, somewhat low on power, and possibly fuel economy issues? Yes, I know it COULD fly up through my hood and anything else like that. Any other issues?
Old Jun 10, 2014 | 06:44 PM
Chevy_King1500's Avatar
buy a new one, and use loc tite.
crank it down to 200+ft/lbs
Old Jun 10, 2014 | 07:43 PM
skaffy03's Avatar
How do I crank it down to specs if the engine turns over?
Old Jun 10, 2014 | 07:54 PM
you will need two people
put a pry bar in-between the flex plate and transmission
Old Jun 10, 2014 | 08:36 PM
skaffy03's Avatar
Well I didn't have a ton of time to dick with it. Ended up using some redneck ingenuity to jam the pulley from spinning without harming it. Hopefully it's on their well enough for me to get it to a shop fairly soon.
I'm assuming that bolt has been missing for 5k+ miles
Old Jun 12, 2014 | 12:20 PM
gagliano7's Avatar
As long as the damper didn't come off you should be fine. I am surprised the damper never moved.
Old Jun 12, 2014 | 12:33 PM
Flyingcat's Avatar
Pick this up on LS1Tech....Works great!
Flywheel flexplate holders - LS1TECH
Old Jun 12, 2014 | 12:42 PM
Txblue's Avatar
I used an ARP bolt when I did my cam swap I just used my snap on 1/2 drive impact to tighten it up and it's been fine fo 26,000 miles. I know tourquing it to spec is best but I was alone and the engine was on a stand.
Old Jun 15, 2014 | 12:22 PM
skaffy03's Avatar
It seems to be on there tight. Bolt is still there!
ferrellrooster
Mar 6, 2025 03:22 PM
roprisiu
Aug 9, 2015 10:47 PM
WarbirdLS1
Aug 8, 2015 10:53 PM
Jake99
Aug 8, 2015 07:56 AM
05GMC4.8
Aug 7, 2015 09:55 PM
