5.3 Liter Engine specs
Old May 9, 2003 | 11:14 AM
Default 5.3 Liter Engine specs
Is there a place that can tell you the specs of your engine. I want to know cam size, if we have roller rockers (size), roller lifters, lift duration. displacement, heads and stuff like that for a 2000 5.3
Old May 9, 2003 | 11:30 AM
oxidizr's Avatar
Moderator / Sponsor
Default Re: 5.3 Liter Engine specs
There are a few places ...
These specs vary from year to year ... what year do you have?
Old May 9, 2003 | 12:12 PM
I HAVE A 2000 5.3 EXTENDED CAB SILVERADO
Old May 9, 2003 | 12:13 PM
Hit Man X's Avatar
The stock cam is tiny, around 200/203 dur .46x" lift, I think. Not as puny as the one in my F-150: 180/183 ~.400" lift. It is really crappy! Peaks at: 185hp @ 3800rpm/270tq @ 2700 rpm!
Anyway, you have 1.7:1 rockers from the factory. They have a roller fulcrum (base) but not a roller tip. SLPs 1.85:1 are just a roller fulcrum too. Yela Terra are bad *** 1.8:1 shaft mounted full roller rockers (tip and fulcrum).
GM has been using roller lifters for a while now, I'd assume since the late 1980's. Your GenIII block does have roller lifters. They read the cam profile far better than flat tappet lifters and wear better too.
Displacement: 5.3 liters, 325 cubic inches, 3.78" bore x 3.62" stroke.
Heads are the 4.8/5.3 variants. They outflow LS1 heads but have smaller valves. 1.89" intake, 1.55" exhaust. I am not 100% sure on the exhaust valve sizing. They have about a 61-63cc chamber, these on a 5.7 GenIII boosts compression.
This is all from memory so the numbers could be/maybe/are slighty off.
Old May 9, 2003 | 01:10 PM
GREGGO's Avatar
Here is some info on the heads to compare with.
99-2000 LS1 heads: #12559853 (for 99-00)
*66.67cc chamber
*200cc intake port, 2" valve dia
*70cc exhaust port. 1.55" valve dia
1999+ L59,LR4,LM4, and LM7: #12559852, 12561706
*61.5cc chamber
*200cc intake port, 1.89" valve dia
*70cc exhaust port, 1.55" valve dia
4.8/5.3 heads really don't offer any advantage to the LS1 heads other than the smaller chamber. They really need a larger intake valve.
Here is a site that might help you get some more engine info: GM poweretrain
Old May 9, 2003 | 03:08 PM
does anyone know what the max power is at from what range of rpm's someone told me they thought from 2200 to 5750 is that right or close?
Old May 10, 2003 | 12:51 AM
CashDudeHomie's Avatar
I heard hp peaks at 5200
Choda
Jan 22, 2026 02:03 PM
steves86ta
Jul 28, 2015 10:21 AM
EscaTruck
Jul 20, 2015 11:42 AM
bsgiffor
Jul 19, 2015 11:14 AM
NuckenFuts
Jul 9, 2015 08:45 AM
