5.3 cammers w/ auto trans
Old Sep 20, 2005 | 08:46 PM
w41quad4's Avatar
Question 5.3 cammers w/ auto trans
So my next project is going to be to throw a new cam in my 5.3 ECSB Z71. Here's the thing, its an auto tranny 3.73 gears and I know how going with too large of a cam with an auto trans w/ stock converter can really make it a dog down low. This is the cam i was planning on running with:
218/221*at .050" 116lsa
or if it will make some more power without being a dog downlow
218/227*at .050" 112lsa
Is anyone running a similar cam on an auto trans w/ stock converter?
I just dont want to lose a ton of power of the line because of the cam w/ the stock converter. I would also really like the sound of a sweet lumpy idle.
So any of you cam experts who can throw some insight i'm listening. My current modifications are as stands
-custom intake
-custome tune *will be retuned for cam*
-EGR removed
-Cats removed
-custom exhaust
*headers & tq converter eventually
Old Sep 20, 2005 | 08:54 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
The first cam would be decent the cam in my sig kille dme down low in my heavy *** truck which you have the same. The stall helps greatly. It all depends on ho wlong its going to be till the stall. I would recommend the stall first cause then when you put the cam in you will get its full performance potential and you will be alot happier with the cam cause you wont notice the bottom end that you lost when you need to haul ***. I would go with a 216/220 on about a 114lsa if it was me and looking fo rwhat oyu are looking for. It will give a noticeable idle and keep some of the power down low but also give you quite a bit up top too. My cam was a highway killer it screamed from an 80 punch to the top of second. At about 3800 you could feel it kick in and push you back in the seat further but below that it was a dog. That cam was good till 6600 in first and 6500 in second so the cam recommended IMO would be good to about 6300 in first and second which will make a big difference. The cam I recommended on a 112 or 110lsa would move the power band down even further to keep more low end if need be.
Old Sep 20, 2005 | 08:56 PM
w41quad4's Avatar
Thanks for the info.
I want to do a stall, but honestly its looking like that's not going to happen until next spring/summer as I plan on having a new trans ready to go in at the same time. So i'm looking for a "right now" basis for cam recommendation.
Old Sep 20, 2005 | 08:58 PM
1slow01Z71's Avatar
The cam that I recommended would work it just wouldnt see its full et drop potential till a stall cause what you gain up top will be lost off the line. I learned that the hard way with my cam. Then i blew the engine and am going with what I original was a h/c 6L with forged pistons so I can spray a 200 shot on it and do 4wd burnouts.
Old Sep 20, 2005 | 09:19 PM
white1's Avatar
I had a 218/224 .562/.568 113 on the stock converter, but my truck is RC so its lighter. It wasn't too bad, till I lined up with someone. Just normal driving it was fine though.
Old Sep 20, 2005 | 10:29 PM
Naked A/V once PM'd me this advice..
Originally Posted by Naked A/V
Here are three cams for you to consider (in the order I would consider them):
Lingenfelter LS1….205/212 .540/.540 116.5
Part # LS1-GT2 $249 from LPE (260) 724-2552
2001-2002 LS6....204/211 .525/.525 116
Part # 12560950 $245.51 shipped from GMPD
2002-2003 LS6....204/218 .555/.551 117.5
Part # 12565308 $250.07 shipped from GMPD
The third one has more exhaust duration than you need (since you don't have a blower), so I would say stick with the first two.
All would work with LS6 springs. The only other items you would need would be hardened pushrods, and a gasket kit.
And I will do it one day. This is based on the 5.3L I have now, and the fact I may never ever get a stall. But it will still work great on a 2600 stall if needed.
Old Sep 20, 2005 | 10:46 PM
what unredeemed posted are some good cams for some thing heavy. like he said the first 2 would be great. if you start going above 550" lift and more than 220 duration bottoms end powers gonna suck. a lower lsa will help bottom end as well. also if you go with a "bigger" cam you have to put in a big stall, and there goes your driveability.
seth
Old Sep 21, 2005 | 08:46 AM
BLACKND's Avatar
Look at the comp cams, ones in the range of 210-212 intake and 216/220 exhaust durations. I am running a comp 216/220 .525/.532 114 LSA and an aftermarket converter 2500 rpm, and in my opinion even that stall is too small for the cam. Definitely not seeing its true potential.
Old Sep 21, 2005 | 07:15 PM
w41quad4's Avatar
Well after taking in all your input I think i've come to a decision on a cam that will meet my needs, so tell me what you guys think. It looks like i'm gonna run this cam:
216/220 114lsa
First off I can get a good deal on the cam, which wasn't a deciding factor but it helps put money in my pocket for other modifications. I just think this cam will still keep good low end torque for my ECSB while really allowing it to pull good above 2k. So it will be streetable w/o a new stall.
I did ponder the GT2-3 cam from LPE but 207/220 with an unlisted LSA seems a bit much for the truck w/ no stall. Any comments on that?
Old Sep 21, 2005 | 09:11 PM
1slow01Z71's Avatar
Hard to tell without the lsa as to how it will really act but I think the cam that you psoted will be just fine IMO.
Jakejack
Jan 8, 2024 10:44 PM
Ls3silverado
Jul 31, 2015 04:22 PM
dantheman1540
Jul 29, 2015 04:45 PM
grantpo
Jul 15, 2015 12:21 PM
GreyChevy
Jul 7, 2015 08:57 PM
