5.3 Build HP expectations
Old Jan 13, 2013 | 07:09 AM
Ron_Stoppable's Avatar
Default 5.3 Build HP expectations
Just want to get a general baseline HP i can expect. The 5.3 is going into my 2000 ext cab S10. Its an (L59)
Specs are
-228r Comp Cam ( IN-.588/ EX- .588 on 114 LSA)
-1218 Springs
-LS1 intake. I plan on upgrading down the road to a FAST or LS6
-BRP 1-3/4 Long tube headers
-stock 35lb FLEX fuel injectors
Transmission- 95 4l80e
-maybe a 3200 Stall to mate with it.
Also should i be worried? I cranked the motor over and i only see oil coming out of certain rockers, Not all. I know i installed the oil pan pick up tube & oring correctly. If i take out the oil pressure sensor oil comes out with like 1/4 of a crank by hand...
Heres a video of me cranking it on the stand
https://www.youtube.com/watch?v=Q1_s...e_gdata_player
Old Jan 13, 2013 | 07:25 AM
TXSZ66AVLANCHE's Avatar
310-320 rwhp
Old Jan 13, 2013 | 09:34 AM
Before tune?
Old Jan 13, 2013 | 09:37 AM
darnie's Avatar
should be close to that... most trucks with cam and heads are around 345-370 depending on the cam and heads. so i think it safe to say around 310-320 rwhp.
btw you'll want alittle more stall with that cam. give chris a call. he spec'd me out a multi disk 3500 for my set up.
Old Jan 13, 2013 | 09:51 AM
Originally Posted by Ron_Stoppable
Before tune?
Stock 5.3 will put down 215-225 rwhp, so adding a 228r cam only to a stock 5.3 310-320rwhp would be a fair statement. Sure it dont sould like a lot but look at the power to weight ratio you have, V8 s10 is fun no matter what!
fastjweb
Aug 15, 2015 10:47 AM
USMCvet0311
Aug 14, 2015 10:28 PM
05GMC4.8
Aug 7, 2015 09:55 PM
OLD BULL
Aug 1, 2015 05:00 PM
06 4.8
Jul 15, 2015 07:17 PM
