5.3 all aluminuim with 799 heads??
Old Dec 5, 2008 | 10:04 PM
jkwalkercchs's Avatar
Default 5.3 all aluminuim with 799 heads??
i found an all aluminum 5.3 they claimed it to be an ls1 so i was excited till i looked on the back of the block and it said 5.3 i has flat tops and 799 heads is it an ho??
its a long block probly needs bearing cause they sat it outside no coil pack or anythang so should i get it for 300$ or walk away
Old Dec 5, 2008 | 10:15 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
walk away.....give me the address?
it's probably an L33 by the sounds of it. If you dont take it....
Old Dec 5, 2008 | 10:40 PM
skyhighsami's Avatar
no title here
There is a bare block on Ebay for 500, so I would take it if you wanted to build something like it
Old Dec 5, 2008 | 11:35 PM
ok so im guessing i should get it im wanting to build a high compression motor to run on propane for my cherokee
im leaning more towards it being an 07
so what can i actually do with it can i bore it to 5.7 i think some engine builder prefers that when he builds 383s hmmm forgot the name read it in engine masters
what kind of flange is on the carbed intake for the ls motors?
Old Dec 7, 2008 | 06:12 PM
Bo185's Avatar
Its an L33 with basically 243 LS6 heads since the 799 early ones.
Old Dec 7, 2008 | 06:45 PM
zippy's Avatar
That's a Trailblazer type 5.3L.
Old Dec 8, 2008 | 04:33 PM
Bo185's Avatar
Its an LH6 then.
http://www.fastfieros.com/tech/vorte..._gen_iv_v8.htm
Old Dec 8, 2008 | 05:28 PM
ForcedTQ's Avatar
I will!!!!
Old Dec 8, 2008 | 05:29 PM
zippy's Avatar
Now that i think about it the L33 also did have the 799's as well as 243's. Intake or camshaft would tell you the difference. Both are very nice.
Old Dec 8, 2008 | 06:07 PM
nighthawk08's Avatar
i would certainly figure out if its a GEN III or IV engine. they dont know what its out of?
$300 is good no matter what but it just depends what you're putting it in.
