is it a 5.3?
Old Mar 28, 2009 | 10:17 AM
lo&sloSierra's Avatar
Default is it a 5.3?
ive came across motor that is suppose to be a 5.3, its out of a tahoe but has flat tops? and its not that h.o motor cause its still an iron block, any way i can tell?
Old Mar 28, 2009 | 11:26 AM
budhayes3's Avatar
PT's Slowest Truck
Sounds like a 4.8...
Old Mar 28, 2009 | 11:42 AM
1Bear's Avatar
If the heads are off of it, rotate it till one piston is at top dead center, then rotate it again till that same piston is at the bottom of the bore. Then just measure the difference, this will be your stroke. A 5.3L will have a 3.622" stroke, while a 4.8L will have a 3.267" stroke. Basically a 1/2" of difference, so you should be able to tell.
Old Mar 29, 2009 | 12:25 AM
alright thanks man...
maxspeed05V
Sep 23, 2015 10:48 AM
nickrench3
Sep 17, 2015 08:48 AM
OVOAustin
Sep 15, 2015 08:32 PM
11MPG
Sep 10, 2015 08:34 PM
11MPG
Sep 8, 2015 04:52 AM
