5.3 to 6.2 engine swap?
Old Jan 29, 2010 | 01:04 PM
05RST2NV's Avatar
Post 5.3 to 6.2 engine swap?
Im thinking of swapping my 5.3 to a newer 405hp 6.2L. I havent done much research on it, just wondering if you guys have made the same swap and how bigga pain it is to do?
Old Jan 29, 2010 | 09:05 PM
nycblazer's Avatar
it should be easy, go for it. You have most of the stuff you need
Old Jan 29, 2010 | 09:14 PM
dlt76028's Avatar
i was also wondering what all is needed for the swap? has anyone put the new 6.2 in a 99-06 truck?
Old Jan 29, 2010 | 10:11 PM
la del 11's Avatar
you *have to change the reluct or wheel or use linginef/lter box from there everything should be easy DI have used the box and had a couple of problems but as longest use mount it in a place where v decent get too much frequency it should work fine with out a problem the box I_havE _Use it and works fine the box is about $250
Old Jan 30, 2010 | 12:17 AM
bohr898's Avatar
Restricted User
instead of the lingenfelter box i changed my reluctor wheel put some rod bolts and main studs in my engine for the same price as the box
.02
Old Jan 30, 2010 | 03:00 PM
05RST2NV's Avatar
Ive heard the cam wheel and extentions for the knock sensors is all you need.. But what about the PCM? Is it compatable?
Old Jan 30, 2010 | 03:02 PM
lablackbeast's Avatar
doesn't know what quit means
you have a pm
Old Jan 30, 2010 | 03:14 PM
05RST2NV's Avatar
Yeah just reading it
Old Jan 30, 2010 | 04:55 PM
dlt76028's Avatar
^^^ share? I also heard those boxes are iffy.
Old Jan 30, 2010 | 05:18 PM
budhayes3's Avatar
PT's Slowest Truck
+1, can't remember when and where I read it (well, I'm sure that I read it either here or on Tech), but I remember reading of some issues with the boxes...
Do the boxes convert old to new (24 to 58) or the other way around? I know that they don't do both...
