5.3 to 6.0, Looks like I need help tonight...
Old Aug 19, 2005 | 10:59 PM
RangerTJ's Avatar
Ok, from the sounds of it, the easy answer is to put a new crank in? Does anyone have a source where I can buy a new 6.0 crank?
Thanks,
Will
BigTex's Avatar
No way to make it fit. Several have tried, none have succeeded. If its a daily driver, you might be up a creek.
I would have a qualified shop do the crank swap if thats your choice. As stated, same stroke in both motors. Rods and pistons from 6.0 will work with the 5.3 crank. May need to be rebalanced if the weight is very different.
4L80 would be even more difficult. Minor wiring difference, PCM is programmed differently, driveshaft length, crossmember is different, transfer case may not have correct shaft, etc...
Old Aug 19, 2005 | 11:04 PM
RangerTJ's Avatar
Ok, now I'm thinking of doing some other stuff while inside. Does anyone make a stroker kit for a 6.0?
Thanks,
Will
Old Aug 19, 2005 | 11:50 PM
budhayes3's Avatar
PT's Slowest Truck
Thanks,
Will
Does this help?
http://www.horsepowerinabox.com/HPIA...tegory10_1.htm
http://www.thunderracing.com/catalog...vid=9&pcid=116
I know there's more...just can't seem to find them right now
Old Aug 20, 2005 | 01:17 AM
BigTex's Avatar
I agree, if you need to swap the crank, might as well put in a stroker rotating assembly. Gains should be incredible over your old 5.3 if you stroke that 6L.
Old Aug 20, 2005 | 06:41 AM
L-EATER's Avatar
11 Second Truck Club
I have always wondered if another solution to this problem might be to have a custom torque converter built for the '60e that has a shorter overall height to make up for the longer crank? Might be worth calling Precision or somoeone and asking if this is feasible.
Old Aug 20, 2005 | 08:21 AM
one03sierra's Avatar
Formerly one92rs
Talking
yay but even if they made a verter that would work the 6.0 would trash it eventually. and oh man if you are going to do an 80e swap. i vote rotating assembly as well. but in the end the 60e isnt going to hold even when built.
Old Aug 20, 2005 | 12:28 PM
litreddevil's Avatar
Banned
Well Their Is A Few That Have Donr It The Center Of The Converter Will Hit All Need To Do Is Put A Shim Between The Flywheel And The Converter. It Will Work.if The Holes R Off To The Side That Little Bit Just Use A Drill An Open Them Up A Little
Old Aug 20, 2005 | 10:11 PM
mason110's Avatar
oh man i dunno about a 6.0 on a 60e to begin with ,just upgrade to a built 65e or a 80e. i think it will tear up that 60e in the matter of a few days
Old Aug 20, 2005 | 11:09 PM
Wilde Racing's Avatar
How do I change this text
It sounds like to me you should just do the 80e swap now, you will be doing it later anyway?
Abuckeye
Aug 19, 2015 06:11 PM
JordanH
Aug 8, 2015 07:59 PM
05GMC4.8
Aug 7, 2015 09:55 PM
OLD BULL
Aug 1, 2015 05:00 PM
steves86ta
Jul 28, 2015 10:21 AM
