5.3/4l60e swap now running lean at idle
Old Dec 7, 2013 | 01:53 PM
operatorfailure's Avatar
Default 5.3/4l60e swap now running lean at idle
I swapped a 5.3/4l60e into my 68 short stepside this summer and it seemed to run great, I tuned it myself with hptuners and had it within 1-2% stft everywhere. Since it has turned cold I have been going way lean when engine is at idle, especially at first start up before it goes into closed loop. I took a video of it to show everyone what is happening. As soon as it gets to 18.0 or so afr it starts breaking up, so I know the wideband is accurate.
https://www.youtube.com/watch?v=wwJi9_2FY1c
Any ideas?
Old Dec 7, 2013 | 02:36 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Possibly intake manifold gaskets???
Old Dec 7, 2013 | 04:21 PM
Honestly I'm really hoping that. I have a knock sensor that went out so I am pulling my intake anyway.
Old Dec 7, 2013 | 06:11 PM
1FastBrick's Avatar
FWIW If the gasket is the Red/Orange type and its smushed down, there no good.
Replace with the new Green/Blue type. They were revised to stand up to the higher ethanol content in the newer gas blends.
Old Dec 7, 2013 | 06:18 PM
Pretty sure it's the red/orange type. I'm hoping this is the problem.
Old Dec 7, 2013 | 06:27 PM
1FastBrick's Avatar
You will know as soon as you take them off.
If there smashed down and nearly flush with the plastic there no good. This happened on mine after I swapped the knock sensors. I didn't buy gaskets and the following week I had to change them out as it started throwing lean codes.
Old Dec 9, 2013 | 10:34 PM
TruckImpressions's Avatar
Registered User
You could always spray carb and choke cleaner around any areas that you think could possibly be a vacuum leak. Just spray the areas and monitor your STFT's or if still in open loop your wide band.
Old Dec 10, 2013 | 06:48 AM
I've been meaning to have the wife come out with me and watch the wideband but with the weather it just hasn't happened.
Old Dec 12, 2013 | 06:36 AM
1Fastbrick, you said
"FWIW If the gasket is the Red/Orange type and its smushed down, there no good.*
Replace with the new Green/Blue type. They were revised to stand up to the higher ethanol content in the newer gas blends."
Does anyone happen to know the part number for the newer gaskets? I am about to order them and don't want the old ones.
Old Dec 12, 2013 | 09:47 AM
1FastBrick's Avatar
The GM# 89060413 Not sure about felpro or any other.
Every once and a while you can score an Ebay deal for about 1/2 price of the dealer list.
