4l60-4l80 swap page, what do you think?
Old Jan 27, 2004 | 12:26 PM
Yelo's Avatar
Nicely Done Jim !!!!
y'know though...on the '97 that I helped do the same swap in we didn't need an adapter harness or different driveshafts......it might just have been the OBS trucks wiring is different than the NBS
Old Jan 27, 2004 | 02:21 PM
Ryan23silverado's Avatar
Awesome writeup Jim This is the stuff that makes this forum great.
Old Jan 27, 2004 | 05:00 PM
Neil 6.0's Avatar
From: as far away from Koonerville as humanly possible
Hey parish, how long is the rear driveshaft now?
Old Jan 27, 2004 | 05:13 PM
parish8's Avatar
single digit dreamer
what part do you want me to measure from?
the driveshaft thing is really nothing, i can get one shortened for $40 and they do it in one day. it was $75 per shaft and that included new u joints. if they can do it in omaha i would think most citys would have a place that could do it.
Old Jan 27, 2004 | 06:32 PM
Good job Parish,the transmission page looks good I'll look to see if I can find the pictures of my 2wds modified crossmember it's a little different than your's with 4wd maybe you can post it on your swap site.
Old Jan 27, 2004 | 06:54 PM
parish8's Avatar
that would be cool, some 2wd drive shaft info would be good too. does the yolk on the 1500drive shaft fit the 4l80 tranny? if not does the u joint on the 2500 shaft fit the 1500 rear? if not did you have any trouble geting the driveline company to merge the 2 shafts?
Old Jan 27, 2004 | 07:25 PM
No the stock yoke won't work,but all you need is the yoke for a TH4OO and a special u-joint to make the stock driveshaft work,no driveshaft shortening is needed on the 2wd.I'll try to find the Spicer part number.
Old Jan 27, 2004 | 07:45 PM
parish8's Avatar
are you positive of that? if so i will add it to the page, part numbers are good, i need to get some more of those.
Old Jan 28, 2004 | 02:34 PM
Neil 6.0's Avatar
Oh, I don't need an exact measurement, just a round-about figure will be fine. But if you have to crawl under there anyway, could ya measure from the tailshaft housing to the yoke on the rear end? Thanks.
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
XL7
May 5, 2022 01:48 PM
Blue03sss
Mar 7, 2019 05:06 PM
jkarnes
Sep 19, 2015 07:11 AM
