427 6.0
Old Nov 30, 2011 | 12:35 PM
CHILLLLLL's Avatar
formerly Stroked-DSM (11/24/2010)
What's wrong with having a stroker for a DD?
Old Nov 30, 2011 | 12:41 PM
Atomic's Avatar
I have a gauge for that
They have increased piston wear due to piston rock at the bottom of the stroke....this really isnt as big of an issue as you think. The LS3 based blocks have longer sleeves so its fine with those.
Old Nov 30, 2011 | 01:05 PM
Robert91RS's Avatar
Take this and factor in the gas a big cube motor will guzzle and the added cost of building it. Where as a stock or mild 5.3/6.0 on boost or juice would still get near stock mpg's and may still outrun a mild 4XXci motor.
ShredSled's Avatar
yeah, if you're dead set on NA, I'd just be looking at some of the preassembled and balanced shortblocks out there. What is your budget you planned on working with?
Did you already have the 6.0 block?
Old Nov 30, 2011 | 01:09 PM
Phantom's Avatar
11 Second Club
naturally aspirated...it's like watching baseball with no steroids
no thanks
Old Nov 30, 2011 | 02:10 PM
ShredSled's Avatar
...so... you get excited watching baseball on steroids?
Old Nov 30, 2011 | 04:15 PM
N/ALS1's Avatar
Lol. Yea I have a 6.0 already. The budget is not one as I'm not in a rush to get it done. But with labor and parts I think I can have the engine installed for total of $6500- 7500. The na thing is fun but maybe a supercharger down the road but not for sure. The funny juice is not my thing. But is a blast to watch sometimes.
Old Nov 30, 2011 | 11:56 PM
Atomic's Avatar
If you want that feel of a big NA engine, try out a procharger. The power comes on different than a turbo or roots-style supercharger; it feels like a huge NA engine since the boost increases with RPM only.
Old Dec 1, 2011 | 04:30 AM
03 BLACKOUTSSS's Avatar
maybe I misunderstood what you are trying to say, but can't the same be said for any power adder that's crank driven? As well as a turbo, being that exhaust gas velocity is generally related to RPMs as well (although I realize there are more variables with the turbo)?
To the OP, slow down, take a minute, relax. Think about what you are trying to do. A stroked DD is not a good idea, if you dont have a back up to drive when it breaks. And its not a matter of "if it breaks"...it WILL break eventually. Pushing a motor close to the edge on a daily basis will find weak spots, either in the sub-par manufacture quality, part design, something. I hate to be the nay-sayer, but I broke a rocker arm bolt on my drive home once. Sounded awful, luckily it was an easy fix. Its just a bad thing to do when you rely of the vehicle to take you to work. If I had it to do over, I would not have changed anything internally (I'm only heads/cam/exhaust). Just too much to be concerned with for my comfort level. Stay bolt ons on the DD and get a toy, or a beater to drive.
I'm not saying it can't be done, but if you ask pretty much anyone on this board that is running a stroked engine, I'm willing to bet that they have another vehicle if something goes wrong.
Old Dec 1, 2011 | 11:07 AM
Atomic's Avatar
Not exactly. Typical blowers and turbos are more related to throttle position. For instance thats what makes a big roots supercharger tricky at low speeds; it has a huge torque increase with just a small change in throttle and not necessarily rpm.
