408 teardown, pics inside
Old Oct 11, 2010 | 10:31 PM
  #71
Atomic's Avatar
I have a gauge for that
Should be stronger than ever when I get it back from HKE or LME.
Old Oct 11, 2010 | 11:26 PM
  #72
LQ4JOSE's Avatar
man that sucks i just read your entire build thread. then i saw the bad new at the end deff sucks.
are you going with a bigger stroke(if you dont mind sharing your plans)?
Old Oct 11, 2010 | 11:34 PM
  #73
Atomic's Avatar
nope, hoping the crank I have is fine and will reuse that. Only internal changes I plan on are slightly dished pistons to lower the CR
Old Oct 12, 2010 | 01:46 AM
  #74
Spoolin's Avatar
GFYS and STFU
Originally Posted by 00K1500
Duh... I knew that about strokers too... thanks for reminding me though! And that's what I thought had occured with your block/crank, just wanted to double check my understanding... Live a little, learn a lot right...
Also on most stroker set-ups the piston skirt will come out of the cylinder at BDC and 'wobble' which slightly rounds the bottom edge of the cylinder walls as well as scuff's the piston.
Old Oct 12, 2010 | 08:51 PM
  #75
1FastBrick's Avatar
Custm2500's Rude Friend
Would a pair of custom throttle body spacers make you feel better???
Old Oct 12, 2010 | 10:52 PM
  #76
Atomic's Avatar
maybe if they were tapped for nitrous
Old Oct 12, 2010 | 10:58 PM
  #77
1FastBrick's Avatar
Actually thats the backing plate flange I told you I was going to make for the 14 bolt... They were supposed to be done last week but the machine went down. A few samples showed up monday. I was supposed to get to the machine shop today so I could tap them, Machine them for the register, and make sure they fit over the Factory tubing.... but like everything else, that fell through....
Old Oct 12, 2010 | 11:06 PM
  #78
Atomic's Avatar
haha, my first thought was dang those looks like some good axle spacers
Old Oct 12, 2010 | 11:10 PM
  #79
skolman91's Avatar
I hope the crank wasnt at fault, cause your truck is on callies site
edit- i just realized you dont have their crank, so your endorsement is still eligible as of now..
Old Oct 12, 2010 | 11:12 PM
  #80
1FastBrick's Avatar
I Just thought I would tease you. They are actually for another members truck. I am having 6 sets made. Cost a few more $$$ then I thought, of course I decided to use 3/4
