408 teardown, pics inside
Old Oct 11, 2010 | 12:33 PM
  #61
Atomic's Avatar
I have a gauge for that
maybe, dont want to ruin the suprise just yet
Old Oct 11, 2010 | 01:01 PM
  #62
SLOXCAB's Avatar
414 turbo???
Old Oct 11, 2010 | 01:46 PM
  #63
Atomic's Avatar
nope, first I need to get the block worked, then I can worry about fun stuff.
Old Oct 11, 2010 | 08:45 PM
  #64
00K1500's Avatar
Been reading through this thread, here comes a couple newbie questions... so I understand the concensus is sloppy build in that the crank wasn't thoroughly checked... so I assume this means some machining of the crank should have taken place but didn't? Second, a comment was made about strokers beating up pistons... any particular reason why a stroker would be more damaging to pistons than a stock stroke? Or are they not? Again, forgive me if my questions seem ignorant, but I figure the best way to learn is to ask...
Old Oct 11, 2010 | 08:58 PM
  #65
Atomic's Avatar
The block should have been machined to make sure the crank journals are perfectly straight and the crank should have been checked for runout and straightness. Strokers are generally harder on pistons because of the angle of the connecting rod at the bottom of the stroke is more extreme than usual and causes "piston rock"
Old Oct 11, 2010 | 09:05 PM
  #66
00K1500's Avatar
Duh... I knew that about strokers too... thanks for reminding me though! And that's what I thought had occured with your block/crank, just wanted to double check my understanding... Live a little, learn a lot right...
Old Oct 11, 2010 | 09:11 PM
  #67
Atomic's Avatar
I dont think that is an issue with mine....just the crank issue.
Old Oct 11, 2010 | 09:29 PM
  #68
00K1500's Avatar
Definitely, thanks for the info though. I'm still learning, have lots left to learn and freely admit it... Half the fun is learning though, In my opinion. Best of luck to you with the rebuild!
Old Oct 11, 2010 | 09:48 PM
  #69
double047's Avatar
14 Second Truck Club
Sucks bro, hope you get her up and running again soon.
Old Oct 11, 2010 | 10:02 PM
  #70
SILVERADO11's Avatar
Hope you get this all straightend out and she runs strong and trouble free for a long time.
