408 camshaft suggestions
Old Apr 3, 2004 | 07:46 PM
StupidFast's Avatar
Default 408 camshaft suggestions
I got my rotating assembly in, thanks AP Engineering. Now the search is on for a camshaft. I would like a descent size cam but, not something I will have to idle at 1,000 or change valve springs ever 10,000 miles. I will keep the truck intake and spray a 175 shot. I will have a 3,400 stall, 10.2:1 compression, and a good set of heads.
I was wondering if I should consider a custom cam for my setup. I believe that most cams for GenIII smallblocks are designed for a car with a shorter runner intake. I was thinking that the intake and exhaust duration should be the same. I figure that the truck intake needs all the help it can get, with getting air into the cylinder. The exhaust has a easier time, full length headers, no cats, and true duals with 2 1/2in. pipe.
P.S. AP Engineering was a pleasure to deal with. I changed my order 3 times and still got the kit quick. Although it will still be over a month before assembly begins.
Old Apr 3, 2004 | 07:50 PM
Banned
thunder racing T-REX but on a 112 LSA or higher if you like higher...and get a damn LSX manifold or an LS6 atleast...that truck unit is junk.
Old Apr 3, 2004 | 08:01 PM
StupidFast's Avatar
Chris@AP-Engineering posted this awhile back:
Here is what I can tell you. I built two 427 engines for a marine application and they made 600 horse at the fly wheel with the truck intake and pulled up to 6800 rpm. I think that you will be fine with the truck intake.
I think the truck intake will do alright with the right camshaft. I really feel that a reverse or standard split camshafts will not work well with this setup.
Old Apr 3, 2004 | 08:09 PM
Flyer's Avatar
I was thinking a standard split ... maybe a 224/230 on a 114. Keep the lift in check, below .550 and you shouldn't have to worry about replacing springs if you get some good ones to start with.
Old Apr 3, 2004 | 08:17 PM
StupidFast's Avatar
I was thinking a custom grind around 230/230@110 at 560 lift. The lsa is low but, I want to make good power with the motor and I have heard that the lsa really doesn't matter with anything under a 200 shot. My buddy has used 112 lsa on a 400 squeeze with another 250 after the 60ft.
Old Apr 3, 2004 | 08:43 PM
I think a reverse split is designed to run with a really big shot of nitrous.With a big shot of nitrous you don't need extra exhaust duration,because the intake charge is carrying an extra charge of oxigen from the nitrous and burns much more effeciently.Maybe a Thunderracing 227/224.569/.563 114.
Old Apr 3, 2004 | 08:44 PM
Banned
under .550 lift on a 408??? you'll have the most under cammed stroker motor in the game...why not utalize all the power that is left on the table with a bigger, more suitable cam for a big motor? a 230/230 .560 cam would be great in the 5.7 you have now though. get a set of isky 295d springs and have someone set them up right, i've hear of guys running .670+ lift on them for extended amounts of time, it's all in the setup. if you go with that small of a cam you'll be very underpowered. that's less lift than the cam that was in my motor, with just barely more lift.
Old Apr 3, 2004 | 08:46 PM
Banned
about the truck intake, i've had several guys that have made several low 9 second LS1s tell me that the truck manifold will become a hindrance at that level....all have reccomended an LS6 manifold at the least, and most say the LSX or a sheetmetal (if you're feelin crazy) would be even better.
Old Apr 3, 2004 | 09:07 PM
Yeah,a LSX intake plumbed with a really big direct port nitrous setup would be really cool.Use a 75 horse dry shot to light things off and then hammer it with 250 horse wet direct port shot once you get moving.750+rwhp would really get that beast down the track in a hurry.
Old Apr 3, 2004 | 09:54 PM
Hit Man X's Avatar
How about a 242/248 .540/.570 112LSA? Should make solid power to about 6600rpms and pull to 7K if you need it to rev that high?
What powerband you lookin for?
