402 build questions
Old Apr 23, 2008 | 10:00 PM
GA95DCMSS's Avatar
Default 402 build questions
I haven't posted much on this forum, but I truly envy some of you guys and the things you've done with your vehicles. Anyway, now that I'm done sucking up, I have a few questions about a LQ4 build up that is going in my 1995 Impala SS in the next few weeks. I'm debating on a 402ci stroker. I'm not completely sure what the stroke is on the stock crank, but with the 4.0 inch stroker crankshaft, would I need to get shorter connecting rods due to the increased length that the pistons are traveling? Or would i be better off going with pistons with offset wrist pins? I'm going to be running the Racetronix LT1 fuel pump with this setup and I'm thinking that 42# injectors should be more than enough for the 402. If you have any suggestions, (besides use search) I'd like to hear them.
Old Apr 23, 2008 | 10:11 PM
dirt track racer 81's Avatar
buying a whole rotating assembly would be the easiest..might as well get the block bored .030 over and make is 408ci
Old Apr 23, 2008 | 10:15 PM
GA95DCMSS's Avatar
Thanks. Any idea where the best place to purchase one would be? I've ordered from Scoggins-Dickey before but I'm not sure if they have any kind of package deals.
5.3lSilverado
25
Aug 29, 2016 12:48 AM
USMCvet0311
Aug 14, 2015 10:28 PM
USMCvet0311
Aug 1, 2015 07:45 AM
bbowerman
Jul 26, 2015 10:57 PM
jmarkway
Jul 18, 2015 09:23 PM
