400 Mild Upgrade
I just purchased a 1976 chevy with a 400 small block. I have no experience in the motor department, and was wondering if I could get some advice from people with experience in these 1970-1980 motors. I am looking for more low end torque/power for pulling trailers and truck pulling at the local fairs in the stock class. I just want a mild upgrade and was hoping I could get some proven upgrades and results from someone with the same motor. Thanks in advance!
Yea it has a 2 barrel on it now. I was looking at the Edelbrock performer series rather than the performer rpm, but I didn't know the difference between the two.
As for the cam, it wouldn't be a problem for me because I have a friend that has done multiple cam swaps because he works at his old mans garage. I just didn't want to go too big and lose power. Is the 270 too big? and is that a Comp Cams 'Magnum' Hydraulic Flat Tappet Cam?
I was also planning on long tube headers, but I was wondering if any of you prefer a brand, and what size of primary tubes to have.
It is a northwest Illinois truck and is going to see a lot of wood hauling, trailer pulling, and sled pulling.
Thank you
Thank you
Thank you
Thank you
always call up the cam companies and talk to a tech. your trucks weight, desired power band, transmission, and gears play a huge factor in what cam fits your needs. i never recommend an off the shelf cam for an engine. what works for some may not work for you. Rochester carbs suck. good luck with that venture.
Also, what carb would you run?
