Which 40+LBS injectors for TBSS intake?
Old Jan 17, 2013 | 06:18 PM
WhiteChevy3's Avatar
Default Which 40+LBS injectors for TBSS intake?
Hey guys i need some bigger injectors for my tbss intake for my mild lq4 build. i have found some on ebay, let me know what you think. i am also UP for Any other suggestions.
8 New 42lb Injectors LS3 LS7 L9
Chevrolet 1986 02 LS1 LT1 42 lbs HR Set of 8 Direct Fit Fuel Injectors | eBay
Thanks guys!
Old Jan 17, 2013 | 06:28 PM
05RST2NV's Avatar
I'm wanting to know this too. I ran racetronics a few years ago and liked them but that was on a old 78mm intake.
Old Jan 17, 2013 | 09:44 PM
KLUG'S SS's Avatar
FormerVendor
I would strongly suggest out of those two choices actually out of the many injector choices out there to go with the factory LS7 injectors. They flow around 42 lb/hr, they are a very good injector and a very big positive aspect of using them is all of the injector data is readily available. Having the right injector data input in the tune is always very important.
Old Jan 18, 2013 | 12:34 AM
oakley6575's Avatar
Aren't the LS7 and LS3 injectors the same?
Old Jan 18, 2013 | 01:09 AM
Three6GMC's Avatar
yes they are both the short type as well as have same EV6 (USCAR) connector. Oh and they would not be a direct fit on any truck style intake without the correct hight adapters like the ones from FAST ($40).
The ones that you need that are a direct fit on the tbss/nnbs intake are the LS2 type injectors. What year is your truck and what type injector connectors do you have?
Heres a FAST LS7 injector to give you an idea of how short they are.
Old Jan 18, 2013 | 12:19 PM
I have a 99 swb. So I have the old style injector connections.So I guess will need the adapters and the 1st eBay injector ebay link for them to fit into my tbss intake
OHsixLS3
Dec 27, 2016 09:30 AM
04450r
Jul 24, 2015 01:58 AM
Ammadien
Jul 22, 2015 08:50 PM
maxspeed05V
Jul 19, 2015 07:08 PM
jrplz
Jul 9, 2015 12:07 AM
