4 corner vs 2 corner coolant crossover tube
Old Oct 18, 2010 | 01:53 PM
Default 4 corner vs 2 corner coolant crossover tube
Not sure what it is to search. I have the 4 corner coolant crossover tube. Mine has a small leak on one of the corners, The local auto wreckers has a 2 corner there that he is willing to part with as its a core engine. Can I put that one on mine or should I look for the 4 corner? The 4 is on a 5.3 and the 2 is on the 4.8.
What is the cost of them used?
Old Oct 18, 2010 | 02:14 PM
dlt76028's Avatar
why not just get new o rings and stick with the 4 corner. otherwise to use the 2, you still need to block the other holes.
Old Oct 18, 2010 | 03:17 PM
It's leaking where the tube goes into the block that bolts to the head. I was going to get the rear blockers as well. Just wanted confirmation if I should or shouldn't do it thats all.
Old Oct 18, 2010 | 03:49 PM
dlt76028's Avatar
I realize that, there are small o rings that prevent it from leaking...
Old Oct 18, 2010 | 03:52 PM
00ChevyScott's Avatar
Wearin' da big hat
I think he means the actual tube that goes into the block David. The o-rings go under the block between that and the head. The tube might have a hole in it where it comes together with the block at the end.
Old Oct 18, 2010 | 03:55 PM
dlt76028's Avatar
Aw thanks for the clarification scott. in that case just go with the 2
Old Oct 18, 2010 | 04:03 PM
Yep thats where its leaking. I'll go with the 2 then as thats all thats readily avaliable. Why are there the differences?
Old Oct 18, 2010 | 09:44 PM
swift700's Avatar
Clean it up good with a wire brush at the leaky joint, heat it up hot with a propane torch and touch some solder to it. Worked perfectly when I modified mine for my TVS. Guaranteed to work.
Old Oct 19, 2010 | 12:05 AM
Good call, i'll try that guess it couldn't hurt.
Old Oct 19, 2010 | 08:24 AM
Rick_Vor's Avatar
Good call. I was thinking the same thing. The piping is so soft some plumbing solder should seal it right up.
Rick
6.0l RST
Nov 23, 2015 11:30 AM
Velocity1
Oct 12, 2015 10:39 PM
Chevy305
Sep 28, 2015 09:21 PM
Velocity1
Sep 15, 2015 11:29 PM
