4.8 vs 6.0 both stock 1/4 mi..and can trans handle it?
Originally Posted by 99Silver6.0
6.0 is FAR better than a 4.8 is. That 5spd prolly will not take it. I would track down a nice T56 and a McLeod clutch for future problems. But I wonder if a 4x4 case will bolt up to a T56?????????????
i think Ford t-case would work?
if i were to blow the tranny i would probably take out the 4wd and use a t56 or soemthing.
If it were me, I'd take the chance on the stock 5 speed holding up, but replace the clutch and pressure plate with heavy duty units. BUT... Don't think that you can start side stepping the clutch to get a good launch, or power shift gears to make a second gear scratch in 4WD mode... then the tranny would be lunch. It's usually not HP/TQ that kills the tranny, it's usually abuse.
Originally Posted by TxSquezze4.8
If I can get mine to hook, I will see atleast 3 seconds diff. in the 1/4 with my LS-1
No Dude. 16.8 STOCK. If I can hook, 13.9 to 13.8 with just the engine swap Dude
