4.8 keeps overheating. HELP??
Old Apr 28, 2011 | 01:45 PM
avengedws6's Avatar
Default 4.8 keeps overheating. HELP??
I have a RCSB with a 4.8L. I have replaced the water pump and the tstat and it still over heats up to 260. Any idea's???
Old Apr 28, 2011 | 03:05 PM
nonnieselman's Avatar
Got a air pocket im guessing..
Old Apr 28, 2011 | 04:06 PM
1FastBrick's Avatar
Custm2500's Rude Friend
What year is the 4.8
Old Apr 28, 2011 | 05:20 PM
bigboy576103's Avatar
Well damn nick you didnt say anything about replacing that already... take the radiator and run water through the top port and seee if it drains out the bottom.. if not it needs flushed duh!! but if not that then make sure the cap on the resevore is making good seal other wise it wont flow right...
Old Apr 28, 2011 | 05:34 PM
sprayedenali's Avatar
whats a good procedure to properly "burp" our trucks?
Old Apr 28, 2011 | 05:48 PM
budhayes3's Avatar
PT's Slowest Truck
There are a few methods, but here's what I do...not only on our trucks but a few different manufacturer's vehicles which are prone to air pockets, and I've never had an issue. I squeeze and pull the upper hose downward, holding it there for a few seconds while air bubbles release in the overflow, which I keep 3/4 full while doing so. I repeat this process many times until I know longer see and feel the air escaping. When I squeeze and pull the hose and nothing happens but the reservoir coolant level raising with my squeezing, I know I'm good to go
Old Apr 28, 2011 | 05:52 PM
pitbull985's Avatar
had a problem for awhile with my 5.3 and it ended up have a clogged radiator so i had it cleaned out for 50$ and never had another prob
Old Apr 28, 2011 | 08:38 PM
andrew383's Avatar
traveling mod
For me having the crossover tube un hooked while i fill up the tank gets my air out
Old Apr 29, 2011 | 08:27 AM
ducky's Avatar
Had a clogged radiator over here as well. Replaced both and water pump and then burped the system. Stays cool like a champ now
Old Apr 29, 2011 | 12:28 PM
I have always taken off the top hose and filled the system with it, when water starts running out of the top of the radiator you should be good. top off the resivior and remove the crossover tube from the passenger side of the radiator to see if any air is coming out.
