4.8 doesn't suck so bad!!
Old Nov 21, 2004 | 11:53 PM
parish8's Avatar
single digit dreamer
Default 4.8 doesn't suck so bad!!
this is a little suprizing to me.
i just went out and ran some gtech's, 10psi, pump gas, closed exhaust, stumble when i punch it. at least 100lbs i could cut, no nitrous
my experience shows add .3 to that time to get an acurate ET. thats a 12.8. . toss in good gas,turn up the boost about 5psi and add a few deg of timing, drop 100lbs, open the cut out, add small shot out of the hole. woohoo, where would that put it?
megasquirt kicks ***, so far the only tuning is about 2 hours worth at 4am last night. i needs a little tweeking still in a couple of spots.
Old Nov 21, 2004 | 11:59 PM
BlownChevy's Avatar
blownerator
25 Year Member
Looks like you could be on the fastest truck list with each motor you do. 4.8, 6.0, 408
Old Nov 22, 2004 | 12:01 AM
Lone Chev's Avatar
Do it!!!
Old Nov 22, 2004 | 12:10 AM
SimpleManLance's Avatar
damn that would be sweet!! you should do it!!
Old Nov 22, 2004 | 12:14 AM
NOSjohn's Avatar
Restricted User
Motor HOG !
Old Nov 22, 2004 | 01:53 AM
GoldenVelvet's Avatar
Clearly the 4.8 is the superior motor. In fact if some one with a 6.0 wants to up grade to a 4.8 just let me know I will pay half of the shipping for my sweat 4.8.
Old Nov 22, 2004 | 02:59 AM
LT1Burnout's Avatar
thats more than a lil suprizing to me.. id like to c that.
Old Nov 22, 2004 | 04:50 AM
sfj
how high are you spinning that thing??
Old Nov 22, 2004 | 04:51 AM
sfj
wow man that is killer you need a 5.3 to het on the list too then you truly would have one of every motor
Old Nov 22, 2004 | 01:18 PM
abbo7's Avatar
Originally Posted by NOSjohn
Motor HOG !
Haha, seriously!
Actually the 4.8 times make me kinda happy inside knowing that it has the umph to run with the big dogs. You should see how much the 4.8L can take, punish it, abuse it!!!!
