4.8 cam questions!
Old Oct 16, 2013 | 02:28 PM
Slowest_1500's Avatar
Default 4.8 cam questions!
I've been looking in to a cam for my little 4.8, I've been eyeing the 212/218 comp cam. I'd like to know what other parts I would need to do the cam swap, and is a converter absolutely necessary? Also is this a good for the 4.8, I see a lot of 5.3 guys with them but not a lot of 4.8? Thanks!
Old Oct 16, 2013 | 02:33 PM
Txblue's Avatar
That would be a great cam for your 4.8. A converter is not nesasary with that cam. You will also need push rods and valve springs. Lifters depending on the mileage on your engine. Ls7 are a good cheap upgrade. If you do lifters you will need head gaskets. I'd also look into long tube headers. And of course a tune.
Old Oct 16, 2013 | 02:51 PM
How much do you think it'll all run? And TSP has that cam, I'm gonna call and see if they make it in a package deal? Thanks for the info btw!
Old Oct 16, 2013 | 02:58 PM
Txblue's Avatar
They do have complete cam swap packages. I think they are around $600 for single springs which will be fine for that cam. You could also run ls6 blue springs with the low lift version of that cam if that's the one your looking at to save some $
Old Oct 16, 2013 | 03:02 PM
Thanks so much man, I'm a noob to this stuff, what length push rods and #valve springs..this is all Chinese to me..
Old Oct 16, 2013 | 03:07 PM
Txblue's Avatar
7.4 is the standard length on pushrods with stock heads and gaskets and base circle of the cam. It's always a good idea to verify with a pushrod length checker $20 part. Although I didn't use one on my set up. Valve springs are your choice. Like I said ls6 springs are cheap and will work great with the low lift of that cam. Tsp will set you up with the right stuff tho.
Old Oct 16, 2013 | 03:26 PM
Thanks a TON man! I'm gonna be hitting up TSP before the end of the month!
RS/SS 4.8
Aug 2, 2015 11:03 PM
USMCvet0311
Aug 1, 2015 07:45 AM
Castro45
24
Jul 31, 2015 07:13 PM
bbowerman
Jul 26, 2015 10:57 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
