4.8 build
Old Aug 17, 2009 | 08:45 PM
javier4.8's Avatar
Default 4.8 build
What's the biggest size I can make the 4.8 go I heard the biggest is a 383 or so. I also have a ls1 bloc. Don't know weather to build the ls1 block or sell it and build up the 4.8. What can I do to the 4.8 come on guys help me out
Old Aug 18, 2009 | 06:42 AM
04Crew's Avatar
Both blocks will use the same cranks and should be able to be bored to around 3.903 so they have the same potential for cubic inches. I think that a few companies make 4.125" or 4.2" stroke cranks which could get you in the 390+ cu in range. However, with that long of a stroke, you a pushing the limits with piston compression height, rod ratio, etc.
Old Aug 19, 2009 | 06:56 PM
L7 Sierra's Avatar
I wouldn't build a 4.8 LS past 5.7 if you want it to run past 150,000 miles. The 408's from what I read can be a bit notorious for killing rings past a 100,000 miles. The deck height is not sufficent to prevent piston rock which in turn kills the bore then rings, but it will be one hell of a motor for those miles.
I am looking at this 05 CCSB 1500 with a 130,000 miles for myself, and if I decide this is the one. I will swap in a 6.0 with a cam, tuning, and full exhaust . It should be close enough to 400 crank hp, and meet CA smog, but I will do the swap after I get all the other bolt-ons in place or the motor gives.
Or if you have a few more dollars a 6.0 or 6.2 with L-92 heads, and a good cam can get close to 500 crank hp CA smog passable. Or build a LS 421 it just comes down to your ability to swipe the card and tolerate motors that don't last that long, but with insane power it may be worth it.
luis_bullz
Sep 8, 2015 03:08 AM
Tigger Welder
Sep 2, 2015 08:17 AM
fastjweb
Aug 15, 2015 10:47 AM
USMCvet0311
Aug 14, 2015 10:28 PM
Cowboy17
Jul 9, 2015 08:22 PM
