4.8 to 5.7
Old May 28, 2007 | 02:54 AM
navy_ao_05's Avatar
Default 4.8 to 5.7
so is it worth the time and money it would take to convert my 4.8 to a 5.7?
most say 6.0 swap but i just got a built 4l60e so i wanna keep it.
how much will it run to convert it?
(i dont mean swap a 4.8 to a 5.7(ls1) i mean make my 4.8 a 5.7)
thanks Robert
Old May 28, 2007 | 03:31 AM
silent1's Avatar
What makes you think the 6.0 won't bolt up to your 4L60E? FYI, it will work.
Old May 28, 2007 | 04:17 AM
nonnieselman's Avatar
Go to a junk yard and find a 6L and just drop it in... everything bolts up.
The Machine shop bill would prob be alot higher than buying a used 6L..
Old May 28, 2007 | 10:04 AM
TXsilverado's Avatar
yes its worth it. im not convinced that the 6.0 pushes much if any more power down than the ls1. people usually recomend the 6.0's because you can usually find them cheaper. a ls1 swap is the exact same swap as a 6.0 swap. use your 4.8's intake, injectors, throttle body, oil pan, front accessories, and flexplate on the ls1 block/heads and drop it in.
Old May 28, 2007 | 10:06 AM
navy_ao_05's Avatar
i wanted to keep the 4.8 block and make it into a 5.7 block.
i thought it was alot of pain in the *** work to get the 6.0 to bolt up to a 4l60e?
Old May 28, 2007 | 10:15 AM
quicksilverado's Avatar
The 60e will bolt up to a 5.7 and 6.0 just like it was the 4.8. If you shop around you can find a used 5.7 cheaper than you can have your block machined and build your 4.8 into a 5.7. You will loose roughly 80 lbs off the front end also.
Old May 28, 2007 | 11:31 AM
nightrunner's Avatar
Mr. Obvious
the 99-00 or maybe 01 6.0s have the longer crank which is for the 80e but just get a 02 up 6.0- and have fun if you want to go that way
Old May 28, 2007 | 11:40 AM
RandomHero's Avatar
Just get a ls1 or 6.0 short block and swap everything over. Which ever you can get cheaper will be your best bet.
AdaMax
May 16, 2016 11:35 PM
legerwn
56
Nov 15, 2015 10:21 PM
97_ek
Sep 23, 2015 09:16 PM
FormulaZR
Sep 14, 2015 05:23 PM
