4.8 to 5.7
so is it worth the time and money it would take to convert my 4.8 to a 5.7?
most say 6.0 swap but i just got a built 4l60e so i wanna keep it.
how much will it run to convert it?
(i dont mean swap a 4.8 to a 5.7(ls1) i mean make my 4.8 a 5.7)
thanks Robert
thanks Robert
yes its worth it. im not convinced that the 6.0 pushes much if any more power down than the ls1. people usually recomend the 6.0's because you can usually find them cheaper. a ls1 swap is the exact same swap as a 6.0 swap. use your 4.8's intake, injectors, throttle body, oil pan, front accessories, and flexplate on the ls1 block/heads and drop it in.
The 60e will bolt up to a 5.7 and 6.0 just like it was the 4.8. If you shop around you can find a used 5.7 cheaper than you can have your block machined and build your 4.8 into a 5.7. You will loose roughly 80 lbs off the front end also.
legerwn
56
Nov 15, 2015 10:21 PM
FormulaZR
Sep 14, 2015 05:23 PM
