4.3L to 5.3 swap
Old Feb 12, 2006 | 01:17 PM
Yelo's Avatar
That's a pretty complicated swap there dude.....there's pretty much NOTHING the same between the 4.3L and the LSx trucks. you're gonna have to change EVERYTHING related to electronics and fuel supply.
If you want to use a six speed do a search on here for "T56 swap", It's not too hard to do and since you're gonna have your truck torn down about as far as is possible to put a V8 into it swapping in the T56 will be pretty straightforward
Major things you'l need to have for the engine swap are: (and this is by no means a complete list)
* COMPLETE wiring harness....Speartech can probably help with this or get one from a junkyard or dearlership
* Custom programmed PCM (correct V8 VIN, programmed for a V8)
* V8 in-tank fuel pump (I've been told V6's use a lower-flow pump)
* V8 fan shroud (or electric fans)
* V8 Radiator
* correct length driveshaft (if you're gonna use the T56)
* V8 induction tubing (and possibly the airbox)
I wish you the best of luck on this swap.....you "may" be better off seeing of you can use the Avalanch you got the motor out of as a parts donor for your swap, it'll speed things up ALOT if you have a reference to look at as well (find a friend with a V8 truck who'll let you park the two side by side during the swap
Old Feb 12, 2006 | 04:31 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Yelo's steering you straight. I've heard Speartech is great with wiring. Allen from NP fabs 5.3 harnesses at a lower cost. Can you find the harness on his truck???
Allen's Engine
Old Feb 12, 2006 | 11:43 PM
hog's Avatar
hog
A vortec 350 swap wouldnt be that difficult, all teh accesories would worka s would your PCM with a reflash.
Just have to add 2 extra injector looms(4 wires) to the PCM and you would be set.
The NBS 4.3 uses the same NBS PCM as the othertrucks. There are 5.7L Vortec Gen1 engines used in the 2001 and 2002 Vans as well as commercial trucks.
Look into this more
Bumpers
Aug 4, 2024 09:44 PM
ARC
57
Feb 21, 2022 10:54 AM
Chiphead
Aug 1, 2015 04:43 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
06 4.8
Jul 15, 2015 07:17 PM
