4.3 to 4.8 quick question.
Old Feb 21, 2013 | 02:16 PM
silverado.408's Avatar
Default 4.3 to 4.8 quick question.
So really quick question for everyone that has done the swap. For the Power sterring pump and alternator can they be used on the 4.8 setup or will I have to get new hoses and crap. Thanks for the help
Old Feb 21, 2013 | 10:42 PM
tfi racing's Avatar
You will need the front bracket castings from the V8's,the only thing that you can use from the 4.3 is the alternator itself.I'm pretty sure the 4.3 PS hoses will work,I will be putting the last pieces of my 4.3 to 5.3 swap together in the next day or two,I can let you know what works.
Old Feb 22, 2013 | 01:45 AM
Ok I already have the brackets from a v8 engine. The only reason I ask is cause its the same part number for both and I dont feel like wasting money on a 2nd pump. Thanks for the help.
Old Feb 22, 2013 | 02:26 AM
_zebra's Avatar
makes children cry
read through these
finally time for some REAL power
https://www.performancetrucks.net/fo...-power-450470/
Old Feb 22, 2013 | 02:31 AM
_zebra's Avatar
makes children cry
the PS pump can swap - you just gotta pull the pulley to swap it over
and the only question i have for you is: WHY a 4.8?! if it was free, i might understand if it woulda been too hard to trade it for a bigger engine
Old Feb 22, 2013 | 03:14 AM
Thats kinda it I got it 90% complete for less than a hundred bucks. Before I deployed I broke it down. And the insides were in good shape. So my original plan was built 4.8 then it went to turbo 4.8 then to built turbo 383 and so on. So im back to a turbo 4.8 cause even though Im deployed the army doesnt pay to well. As of right now im still going turbo 4.8 route but lq4's on ebay come complete for 1000-2000 bucks. So I might change my mind again.
Old Feb 22, 2013 | 06:41 AM
Well been doing some looking around and thinking. If i go from a 4.3 to 4.8-5.3 I have an idea of what I need. My question is if I go from 4.3 to 6.0 will the harness that comes with that motor work on my truck. The truck is an 07 classic 2wd rcsb. I know that lq4 are normally mated to 4l80e which is cool cause I was planning on swapping to that anyway. But if it came from a 2500 truck will the wiring be any different. I just don't want to have to buy 2 harnesses. Anybody have any idea?
Old Feb 23, 2013 | 11:29 AM
tfi racing's Avatar
The 4L60E wiring is slightly different than the 4L80E wiring,get the harness with the transmission.Not a big deal to change the 4L60E harness, 4L80E adds a second VSS and the big connector needs to be repinned.
Old Feb 23, 2013 | 11:50 AM
_zebra's Avatar
makes children cry
the rest of the harness should be fine
Old Feb 24, 2013 | 08:06 AM
ok so would I be correct to assume that if I get a lq4 that its already going to be setup for a 4l80e?
